Forum topic by Beuford | posted 02-28-2021 06:12 PM | 289 views | 0 times favorited | 3 replies | ![]() |
Ok, long, detailed post… Sorry! I recently purchased a used Delta table saw marked 36-670. The arbor bearing sounded a bit noisy, so I pulled it apart to replace the bearings. As I took it apart I realized that it wasn’t the bearing causing noise, but instead the movement of one of the spacers (#206 in the parts drawing). Reviewing the parts list and the actual parts, it looked to me like the inner bearing races should be coupled under pressure via the blade support, bearings, spacers, pulley and finally the pulley nut (see my top hand drawing). But under that assumption the long spacer (#206) should not be loose. I reassembled the bearings and shaft and low and behold I had the same condition as before – the long spacer was slightly loose. Didn’t seem right… I investigated further and realized that the slightly wider part of the shaft where the pulley-side bearing seats – diam 0.669in – was a little longer than the inner bearing race. Further, I found that the short spacer (#211) – which I assume sits against the pulley-side bearing inner race – has an inner diameter of only 0.625in. The result is that the short pully-side spacer (#211) seats not against the bearing race but instead against the bearing seat in the shaft (see the second hand-made drawing). Thus the long spacer is never compressed between the two bearing inner races. The saw looks all original, so I doubt that the short spacer has been incorrectly replaced. So I’m wondering: has anyone else seen this on a Delta 36-670 series table saw when replacing the bearings? Part list: My drawing(s): Thanks in advance, Beuford |
