right to left ruler
« back to Hand Tools forum
Forum topic by tvrgeek posted 02-28-2021 01:57 PM 614 views 0 times favorited 35 replies Add to Favorites Watch
View tvrgeek's profile
tvrgeek
1749 posts in 2701 days
02-28-2021 01:57 PM
Topic tags/keywords: question
Looking for a 8 or 12 inch right to left ruler for setting up my TS easier than reading up-side down. Plenty of flexible and tape, a few but with overhangs ( don’t start at zero) Can’t find one. Anyone know of a source?
Stainless, etched, 32 graduations preferred.
35 replies so far
View 987Ron's profile (online now)
987Ron
789 posts in 368 days
#1 posted 02-28-2021 02:29 PM
Lee Valley has left and right handed tape measures, not sure about stainless rulers.
-- Ron
View Madmark2's profile
Madmark2
2492 posts in 1640 days
#2 posted 02-28-2021 03:01 PM
You’re gonna kill me – try Incra.
-- The hump with the stump and the pump!
tvrgeek
#3 posted 02-28-2021 03:16 PM
Believe it or not, I looked there already. :) Did not find one. Looked at Woodpeckers too.
GOOGLE only has tape or one that has an overhang so not starting at zero. I guess I could grind one down, but rather find what I am looking for. McMaster carries a lot but no right to left.
I guess the easy thing is to get a $6 stick-on and stick it on the back of one of my others. Seems odd though.
You re gonna kill me – try Incra.
- Madmark2
View splintergroup's profile
splintergroup
4969 posts in 2274 days
#4 posted 02-28-2021 04:13 PM
They seem to be available from several sources
View PaulDoug's profile
PaulDoug
2523 posts in 2755 days
#5 posted 02-28-2021 04:31 PM
How about a ruler off of a combination square… the bottom row of numbers goes on way the top the other… Doesn’t that make it a both?
6920 posts in 3545 days
#6 posted 02-28-2021 04:43 PM
Not having overhangs is a problem I’ve been facing, I would like to have a couple more for the shop (not necessarily lefty/righty) and can’t find them anymore. Maybe someone will post a lead, but so far my search has found bupkis.
View Robert's profile
Robert
4520 posts in 2533 days
#7 posted 02-28-2021 04:44 PM
Lee Valley Utilas hook rulers read both ways. But only go to 16’s if that matters.
tvrgeek
#8 posted 02-28-2021 08:41 PM
Use case is for setting the TS fence. No hook, no overhang, not flexible. Lay it down and get the last RCH measurement to a tooth.
If you look at the combination square, you see the scale is still left to right, just up-side down.
The one McMaster sells for $68 is available elsewhere for about $12, but it has an overhang.
I may give their aluminum ones a try as closest I have found, but I did not want “flexable” and want 1/32 markings.
View bigJohninvegas's profile
bigJohninvegas
978 posts in 2514 days
#9 posted 02-28-2021 09:29 PM
Lee Valley has them, the link is a Starrett branded one that comes in several options.
If you search the ruler section, I believe there are several options, Like a Lee Valley branded version, Cheaper price tags over Starrett.
https://www.leevalley.com/en-us/shop/tools/hand-tools/marking-and-measuring/rules/71671-starrett-spring-tempered-precision-rules-with-end-graduations?item=30N3162
Karda Asked this same question last month. My reply has a list of what Lee Valley has available.
I spent a fair amount of time looking it all up then. lol.
https://www.lumberjocks.com/topics/312945
Hope this is what you are needing,
Good luck.
-- John
bigJohninvegas
#10 posted 02-28-2021 09:32 PM
- splintergroup
My eyes are not what they used to be, And I like the High Contrast rules here.
-- John
tvrgeek
#11 posted 03-01-2021 09:41 AM
Again, all the rulers mentioned are labeled left to right. Not right to left. It is a minor nuisance reading them up-side down which is my reason for looking. Only the black aluminum one is right to left.
Robert
#12 posted 03-01-2021 12:01 PM
I don’t think you saw the ones big John mentioned? Did you look at the ones I mentioned?
tvrgeek
#13 posted 03-01-2021 12:08 PM
Yes I did. Only the black aluminum ones are close. Kind of wanted steel, but will probably order one.
The first one is steel, but had an overhang, so useless for this application.
View LittleBlackDuck's profile
LittleBlackDuck
6923 posts in 1873 days
#14 posted 03-01-2021 12:30 PM
After shitcanning Kreg on another post I feel hypocritical recommending them… However, they supply both ways in tape “rulers”... stick on and I believe magnetised as well… I bought mine many years ago but it was from an Australian supplier and I’m sure if it’s available locally it’s available in Yankeeland... and I don’t expect it to be out of production.
View Ocelot's profile
Ocelot
2972 posts in 3690 days
#15 posted 03-01-2021 12:34 PM
Pec steel rulers are numbered both ways on the inches, but not on the 32nds.
-- I intended to be a woodworker, but turned into a tool and lumber collector.
showing 1 through 15 of 35 replies
