Forum topic by Robert | posted 02-26-2021 08:33 PM | 279 views | 0 times favorited | 10 replies | ![]() |
I’m having a heck of time finding BIN shellac based, which is my go to. I’d rather not get into a lot of thinning & something that dries or sand quickly. -- Everything is a prototype thats why its one of a kind!! |
10 replies so far
#1 posted 02-26-2021 10:12 PM |
Huh????? -- Alaskan's for Global warming! |
#2 posted 02-26-2021 11:28 PM |
Yeh. The last time I bought some I had to order it. My local big box only sells the rattle cans for some reason. For spraying, I’m not sure what a good alternative is. |
#3 posted 02-26-2021 11:54 PM |
Bought the last 2 at one of the HD’s in my city. AK guy that didn’t make sense, did it? -- Everything is a prototype thats why its one of a kind!! |
#4 posted 02-27-2021 12:11 AM |
Rust-Oleum owns Zinsser which seems to be a primary source of the B-I-N Shellac base primer. It should be avaliable in most big box stores. If you don’t need the opaque hiding qualities of the BIN you can get Zinsser’s shellac primer sealer which is clear. It is in a 2# cut shellac. -- Les B, Oregon |
#5 posted 02-27-2021 05:15 AM |
?? It has been harder to find at Lowes last I checked? If you have Sherwin Williams nearby, the neighborhood homeowner stores stock a shellac based primer that acts about same: YMMV -- If it wasn't for bad luck, I wouldn't have no luck at all, - Albert King - Born Under a Bad Sign released 1967 |
#6 posted 02-27-2021 12:52 PM |
I guess it’s a local supply thing. I ordered a gallon on Amazon and got a delayed delivery notice followed by “your order was cancelled. I did t know about the SW product, kinda pricey tho. -- Everything is a prototype thats why its one of a kind!! |
#7 posted 02-27-2021 01:10 PM |
Most are now all water based. Low VOC and do not seal or hide like the the old stuff. Have you tried automotive lacquer primer? |
#8 posted 02-27-2021 01:18 PM |
If you are willing to spray lacquer.. Lenmar duralaq. (available from your local Benjamin Moore store) $25/gallon locally and night and day better than BIN. |
#9 posted 02-27-2021 06:07 PM |
+1 If spraying cabinets white, both solvent or WB lacquer is better choice than BIN shellac on new wood. BIN shellac is intended to fix problems on old wood, not seal new wood. Solvent based lacquer has advantage of being one of cheapest options too. When spraying finishes, the finishing world has plethora of fantastic choices. Depending on top coat, there are many good choices for wood primer. IME shellac is one of harder finishes to sand smooth. For Poly or WB coatings, commercial recommendation is use vinyl based grain filler/primer. When spraying lacquer; can get easy to sand, white out, primer versions too. Your profile shows NE FL. Suggest you call or stop by Duval Paint in Jacksonville. They carry both Chemcraft and Lemnar commercial wood coatings. Can also contact Richelieu in Jacksonville for commercial wood coatings too. They carry Mohawk, ML Campbell, and SIVAM (has great WB 2K poly). Best Luck. -- If it wasn't for bad luck, I wouldn't have no luck at all, - Albert King - Born Under a Bad Sign released 1967 |
#10 posted 02-27-2021 10:06 PM |
So I found this out after I drove 20 miles and bought 2 gallons? I am not a professional painter nor do have pro equipment, but thx for the info. Truthfully I’m confused enough as it is about paint and finishes. I’m going with what I know works for me and my spray set up. I’ve been using it for years and never had an issue. I’ve painted a couple built ins and 2 vanities using BIN primer they both look fine. Re: new wood, I don’t think it’s debatable that shellac is an excellent sealer so I’m not sure where you’re coming from there. I’m using Target Coatings pigmented lacquer for the finish coat. They also have a primer that I may give a go. -- Everything is a prototype thats why its one of a kind!! |
Forum | Topics |
Woodworking Skill Share
13246 |
Woodturning
2830 |
Woodcarving
578 |
Scrollsawing
417 |
Joinery
1914 |
Finishing
6400 |
7942 |
32946 |
CNC Woodworking
335 |
Hand Tools
6488 |
Jigs & Fixtures
1825 |
Wood & Lumber
7310 |
1647 |
Focus on the Workspace
2644 |
1273 |
Woodworking Trade & Swap
5436 |
LumberJocks.com Site Feedback
2401 |
Coffee Lounge
9685 |
