Another DeWalt 735X jammed raising/lowering thread
Forum topic by nickbatz posted 02-26-2021 08:20 PM 538 views 0 times favorited 11 replies Add to Favorites Watch
View nickbatz's profile
nickbatz
692 posts in 1131 days
02-26-2021 08:20 PM
Topic tags/keywords: planer question
So my 735X’s mechanism is jammed.
The repair person who fixed it a few months ago told me (on the phone, without having seen it) that it’s rust – which may well be true, but it’s been covered in a screened-in porch in Los Angeles. He says it will need taking apart and cleaning… which was $100 last time, but all things being equal I’d rather not spend that again.
Anyway, it was working fine a week ago, so if it’s rust it happened all of a sudden. I have a feeling it’s out of alignment again, but this guy does have a lot of experience and seems to be very good.
Question: should I try WD40 on the poles and chain, or will that just destroy good grease along with bad stuff?
TIA
11 replies so far
nickbatz
#1 posted 02-26-2021 08:24 PM
Bonus question, while my mind is on the subject:
The outfeed extension wing thing on this machine is missing springs or something that hold it level, so it’s a little low and I end up holding it up a little to support the wood as it exits.
With regard to snipe, is that worth fixing, should I bother with a “sled” as an alternative, should I just live with it…
The subtext is that the depth gauge will then be off a little, even though I do know how to add 1/2” or whatever.
View RClark's profile
RClark
111 posts in 3236 days
#2 posted 02-26-2021 08:51 PM
My first impression is that it’s gonna cost you a minimum C-note if you take it in anyway, so why not just try the WD40 on the posts anyway?
What was wrong with it a few months ago that you had to get it fixed? (Maybe you discussed this in a previous post from back then and I haven’t seen it.)
Is there really grease on the posts?
Don’t go crazy, but see if you can gently get the WD40 to soak into the minute gap between the posts and the mechanism and see if you can get it loose. If successful, you can then clean the posts with a fine polish of 0000 steel wool and then lube again. Try to avoid getting any of the WD40 on the feed rollers.
That’s how I clean the posts on my Delta planer (going on 20 years old, and it’s never been to the shop).
-- Ray
nickbatz
#3 posted 02-26-2021 09:39 PM
Thanks Ray.
I bought the machine used, knowing full well it would need to be taken in for repair if I couldn’t do it myself. it was the same problem, only it was misaligned then, and because of what the guy said + the fact that it went bad without being touched, I’m skeptical that it’s the same cause this time.
Your estimate of $100 is spot on – that’s what it cost to have repaired. But it was still a good deal ($250 + $100), and the machine really does do a great job.
View pintodeluxe's profile
pintodeluxe
6344 posts in 3864 days
#4 posted 02-26-2021 10:02 PM
I use dry lube on mine.
nickbatz
#5 posted 02-26-2021 11:30 PM
Ah, good idea. I have a can of that stuff that I bought for something similar. Didn’t think of that!
Thanks.
nickbatz
#6 posted 02-27-2021 10:16 PM
FIXED.
It was just sawdust gumming up the works. I blew it out like crazy with a shop vac, then used a dull knife while cranking it (so it turned) to loosen jammed sawdust that didn’t blow out.
And then used the dry lubricant. Why not.
Now it’s practically begging me to raise and lower it, it moves so nicely. Very satisfying. :)
Kids, do this at home: blow out your thickness planer after using it.
nickbatz
#7 posted 02-27-2021 10:24 PM
Did I mention how satisfying it is?
Who would have thought turning a crank would be so much fun.
RClark
#8 posted 02-27-2021 10:31 PM
Very cool!
-- Ray
View Bstrom's profile
Bstrom
341 posts in 224 days
#9 posted 02-27-2021 11:27 PM
FIXED.
It was just sawdust gumming up the works. I blew it out like crazy with a shop vac, then used a dull knife while cranking it (so it turned) to loosen jammed sawdust that didn t blow out.
Now it s practically begging me to raise and lower it, it moves so nicely. Very satisfying. :)
- nickbatz
I was just getting ready to say – keeping these things really cleaned out is imperative. My 734 gets fully blown clean each time I use it. Actually almost all my power tools do…dry lube will work for a good while but not forever. Setting aside some time for multiple tool maintenance makes the very next shop session really fun…
-- Bstrom
View Madmark2's profile
Madmark2
2487 posts in 1639 days
#10 posted 02-27-2021 11:30 PM
Don’t use steel wool to clean the leadscrews. The debris will get in the bearings and is impossible to remove.
Use a green Scotchbrite pad instead. Its tough enough to scour but won’t leave destructive steel lint.
-- The hump with the stump and the pump!
nickbatz
#11 posted 02-27-2021 11:34 PM
Makes sense, Bstrom, especially if like me you’re not using your machines every day.
Don t use steel wool to clean the leadscrews. The debris will get in the bearings and is impossible to remove.
Use a green Scotchbrite pad instead. Its tough enough to scour but won t leave destructive steel lint.
- Madmark2
While I don’t know what leadscrews are, I didn’t use anything to clean this thing out other than air and a dull knife to knock loose trapped sawdust.
But regardless of what leadscrews are, that sounds like good advice for many applications.
