Forum topic by tcaz | posted 02-25-2021 11:11 PM | 378 views | 0 times favorited | 7 replies | ![]() |
Looking for some guidance on dimensions for the base of this record player console. It’s one of the larger/longer builds I’ve made and want to make sure it doesn’t have any weak points. The piece will hold records albums on the bottom, knick knacks in the middle shelf, and hold a record player/misc decor on the top. The case is constructed from 3/4” alder veneer ply and measures 84×15x23.5”. And my tentative plan for the base—made from solid alder with approximate final dimensions of 72×12x6”. The (4) legs will be 1.75” thick with a double curved taper (mock up in photos below). Stretchers/rails will be made from 5/4 alder and 2-2.5”H. All joined using dominos. Considered two additional legs in the center though unsure if necessary? Do you see any strength concerns with this idea? Any areas that need reinforcement (cross members) to prevent sagging in the middle? Any advice would be helpful! |
