Forum topic by MrRon | posted 02-25-2021 10:55 PM | 338 views | 0 times favorited | 7 replies | ![]() |
I have some urethane (orange) tires to install. One side of the tire is shiny and the other side is dull. My question is: what side goes against the wheel’ the dull side or the shiny side, or does it matter? |
7 replies so far
#1 posted 02-26-2021 12:28 AM |
Get ahold of Sulpher Springs Mfg. in Florida. They probably made them. The rough side should be IN if you have to use 3-M weatherstrip adhesive to keep them from jumping off the wheel. |
#2 posted 02-26-2021 02:06 AM |
One side should be flat, the other should have a slight crown. The flat goes on the wheel. -- Jim, Georgia, USA |
#3 posted 02-26-2021 03:44 AM |
Sulpher Grove has an excellent video for installation. https://sgtool.com/2016/09/20/hot-water-or-not-installing-band-saw-tires/ |
#4 posted 02-26-2021 09:02 AM |
I installed the orange ones from Sulphur groove tools on my jet 18” last year and had the same question. I called over and talked with Rick and he said it really does not matter but likes to install the shiny side towards the wheels. If yours have a crown I suspect the crown would go facing out. Mine were flat both sides and I installed them without and adhesive they are are working great. A well worth while upgrade even though I almost killed myself a few times trying to stretch those things |
#5 posted 02-26-2021 10:50 AM |
My tires don’t have a crown; they are flat. |
#6 posted 02-26-2021 04:29 PM |
I used the SG tool tires for my Powermatic 141 restore a while back, the tires were flat and my wheels are also flat. The SG website shows a way to create a crown with several strips of tape between the tires and wheels, worked great! |
#7 posted 02-26-2021 06:04 PM |
When I mounted my tires (17 inch) in the winter, it was 40-something degrees in the shop and them things don’t stretch very well – especially when cold. So, I use a couple of those clamps that convert to spreaders. That helped a lot. I don’t remember about shiny vs. dull sides. -Paul -- I intended to be a woodworker, but turned into a tool and lumber collector. |
Forum | Topics |
Woodworking Skill Share
13250 |
Woodturning
2831 |
Woodcarving
580 |
Scrollsawing
417 |
Joinery
1914 |
Finishing
6408 |
7948 |
32964 |
CNC Woodworking
335 |
Hand Tools
6491 |
Jigs & Fixtures
1826 |
Wood & Lumber
7313 |
1647 |
Focus on the Workspace
2645 |
1273 |
Woodworking Trade & Swap
5439 |
LumberJocks.com Site Feedback
2401 |
Coffee Lounge
9686 |
