What table saw blade do you recommend using to cut the grooves/slots in the rails and stiles of a shaker cabinet door to fit the so called ¼" plywood panel of today? Flat bottom cut is needed.
Or, what router bit would you use instead? Links are appreciated. larry
Those would be rip cuts and since the groove would need to be .2" wide (or something that's not .25"), I would just use a rip blade and make 2 cuts to get the proper width….or the undersize router bit. I'd probably go with the rip blade, they do cut flat bottom kerfs.
If you are only cutting a few it is usually not worth investing in a new cutter.
Fred had it right on in his comment above.
Why if a plywood panel is going into the groove and cover it does it need to be flat?
Those would be rip cuts and since the groove would need to be .2" wide (or something that s not .25"), I would just use a rip blade and make 2 cuts to get the proper width….or the undersize router bit. I d probably go with the rip blade, they do cut flat bottom kerfs.
Not really a fan of undersized bits for plywood. Depending on where you get the plywood, it's not all uniform thickness, even at the known undersized thickness.
We only have a Lowes store here and the selction isn't so good. Is there one in Lowes that you know would meet these needs. The way they have these labled confuses me. Some don't even have a designation.
I have my whole kitchen to do then no more. larry
P.S. I may run down to Keim Lumber in Charm tomorrow as I am in a bit of a hurry.
No thats a combo blade a flat top is a rip blade. Look for a 24 tooth rip.
IMO if you have to do very many of these, your better off with a rail and stile router bit set b/c you have another set up for the tenons. Not a big deal but does save time. You need a router table set up, tho.
My experience lately with plywood is the thickness varies greatly from sheet to sheet, so even the undersized plywood bits will not give you the proper fit. Some sheets will be too tight and some will be too loose. Same is true for mdf. When I made the doors and drawer fronts for our office upgrade I ended up bring a sample rail to the lumberyard to find a sheet of mdf that fit it properly.
If you can find it, some mdf core plywood comes in full 1/4" thickness. One of my local big box stores (Menards) used to stock it in Cherry, Oak and Maple and you could special order other species. Now what they stock is less than a 1/4" like typical plywood.
We only have a Lowes store here and the selction isn t so good. Is there one in Lowes that you know would meet these needs. The way they have these labled confuses me. Some don t even have a designation.
Right now, looking at the listings, I would have to say neither one of those blades will cut a flat bottom.
First, other listings for blades that cut flat-bottoms are usually clear about that feature. Neither one of the listings states a flat-bottom cut specifically.
Second, the Amazon listing has a drawing of the grind specifications. That drawing shows a .006" difference between the top of the flat tooth and the top of the beveled tooth AND the beveled tooth is higher than the flat grind tooth. Here's a snip:
Second, the Amazon listing has a drawing of the grind specifications. That drawing shows a .006" difference between the top of the flat tooth and the top of the beveled tooth AND the beveled tooth is higher than the flat grind tooth. Here s a snip:
- RClark
That s going to give you clean, sharp corners. It s still going to be flat. Dado stacks cut the same way.
Well…I don't own any CMT saw blades, so I went out and looked at my Freud blades that have a similar configuration. I wanted to check the advice I gave; I'd hate to to prompt somebody to act on something that is false. I realize it may not be an apples-to-apples comparison, but I'm going to have to stick with what I said: I don't think the CMT blades linked will cut flat bottoms.
Here's what I found on my Freud blades. My standard blades right now are Freud LU83 50T thin-kerf combo blades. They have alternating top bevel grinds. Every fifth tooth is a flat top tooth just like the referenced CMTs. I have three of them.
From Freud's web site the blade spec is:
The site doesn't give any information about the difference in height of the flat top tooth compared to the beveled tooth, unlike the info on the CMT. The Freud site also does not claim that the LU83 will cut flat bottoms.
I ran a piece of maple scrap through two of the Freud blades. The bottoms are not flat. Pic:
Full disclosure: My Freud blades are not new; they have been resharpened by the place that does all of my sharpening; they service many industrial customers of all sorts and I trust they did it right. I suppose it's possible that they modified the grind in some way that "took away" the ability for my blades to cut flat bottoms.
I still can't say whether or not those CMT will cut flat bottoms. But, based on what I saw in their literature, I don't THINK they will.
Hopefully somebody who has one of the CMT blades can confirm one way or the other.
If i don't have a flat bottom the top and bottom of the stiles will not close and have to be filled. The wood will be finished not painted. Or am I missing something in all of this. Not sure. larry
Combo blades are a compromise. They'll do a decent but not perfect job on both rips and crosscuts.
That Freud LU83 is a favorite of mine. They leave a wavy bottom as you have found.
If an absolutely flat bottom is needed a router is called for.
For best results rough the dado with the saw. Cut it a little narrow and shallow. Perfect the dado with the router. Its more effort but will give a great looking join without chewing up bits. As always I suggest carbide.
I don't go nuts that sometime the ply can be a little wavy. I cut for the thinnest, test fit & lightly sand the high spots to fit. Since the edge is in the middle of a dado it will never be seen.
FYI:
The diameter of the average human hair is about 0.003". The 0.006" tooth height difference is literally the width of two hairs.
FWIW:
Multiple saw passes tend to leave a minor ridge depending on feed pressure, alignment, etc. Router will leave dead flat bottom without a hint of a ridge.
You could always use the router bits for this project and turn around and sell them if you don't think you will use them again. Even if you only get 1/2 of what you paid it might be worth it in the long run. Whiteside, CMT, Freud are all good.
If i don t have a flat bottom the top and bottom of the stiles will not close and have to be filled. The wood will be finished not painted. Or am I missing something in all of this. Not sure. larry
I might get into trouble here but I bought a pair of CMT blades the other day. Other than the very top of the line Freud blades I have never been a fan of them. The CMT blades are better to me. And there are many blades better than both. Just my thoughts don't be afraid of a CMT blade if you decide to go that way. Regards
Thanks guys. I bought a flat bottom 10" at Keim lumber and i'm going to try it out on my table saw. If that doesn't work for me then i will buy a router set and go from there. larry
Related Threads
LumberJocks Woodworking Forum
2.5M posts
96K members
Since 2006
