Curved leg article - can’t find
Forum topic by leftcoaster posted 02-25-2021 07:00 PM 290 views 0 times favorited 6 replies Add to Favorites Watch
View leftcoaster's profile
leftcoaster
384 posts in 1932 days
02-25-2021 07:00 PM
Sometime in the last couple of years, Woodsmith (I think) published an article about making curved table legs. I can’t locate it and am hoping someone here will recall it.
This was specifically about laminating legs, but not bent lamination. Rather it was a glued up post that could be band sawed to the final shape. The glue up added material at the base so that you didn’t need a super thick piece of stock to make the entire curve. I think there was a rabbet so that there was more “meat” at the glue line.
Ring any bells?
View Lazyman's profile
Lazyman
6932 posts in 2443 days
#1 posted 03-07-2021 03:55 PM
Is the curve leg end table the one you are looking for? If not and you know specifically which type of project it was, you can try more extensive searches on that webpage.
leftcoaster
#2 posted 03-07-2021 06:32 PM
- Lazyman
Unfortunately not. I’m not having a lot of success with their search either. Thanks for trying though!
Lazyman
#3 posted 03-07-2021 11:19 PM
If you’ll give me a little more information about what kind of table and maybe about how long ago you think it was, I’ll give the search one more try.
leftcoaster
#4 posted 03-08-2021 12:50 AM
If you ll give me a little more information about what kind of table and maybe about how long ago you think it was, I ll give the search one more try.
- Lazyman
Don’t recall the table. The legs flared out at the bottom. Trick was to glue on two blocks at the bottom into which you could cut the flare without using an entire large piece of stock that realistically wouldn’t exist. So imagine a 1.5×1.5. Glue another 1.5 piece on one face. Then glue smother that is 3” wide across both pieces. Now the bottom is 3×3 square and the top is 1.5×1.5 square. Cut the leg at the bandsaw.
Lazyman
#5 posted 03-08-2021 02:54 AM
See Issue #245, October 2019, page 56 : Search Glued up legs. I think the legs are actually for a cabinet.
leftcoaster
#6 posted 03-08-2021 04:08 AM
- Lazyman
THAT’s IT!!! Thank you SO much!
