Forum topic by kaitlyn2004 | posted 02-22-2021 09:22 PM | 298 views | 0 times favorited | 14 replies | ![]() |
I’ve got a Ridgid WD4050 shop vac hooked up to a Dustopper and wanted to add a remote switch for the vac. I came across something like this: https://www.amazon.ca/gp/product/B01HWB0TPU It lists 15A, which should be great, but then says only 1/3HP – virtually any shop vac will be more than that? Would this switch work with my shop vac, or do I need something totally different? |
14 replies so far
#1 posted 02-22-2021 09:33 PM |
Just go by amps/volts/watts. Shop vac HP is a made up number, they could easily say Kajillion Horsepower. |
#2 posted 02-22-2021 09:34 PM |
Personally, I like to de-rate by 50%, but it is darn cheap, so give it a shot. |
#3 posted 02-22-2021 09:58 PM |
The horsepower rating of a switch relates to the ability of the switch contacts to dissipate the stored energy of the motor’s magnetic field when the motor is shut off. Going over that rating will reduce the life of the contacts. It’s a cheap switch. If it fails in a week look for different one. If it fails in a year just replace it. -- Dave, Tippecanoe County, IN --- Is there a corollary to Beranek.s Law that applies to dust collection? |
#4 posted 02-22-2021 10:40 PM |
The 5HP is imaginary number. If you want to be ‘cheap’, This remote control might work, as the relay inside is rated for 1HP. By time you add plugs, receptacle, and box to keep things neat; might be able to buy remote made to dust collection for similar cost? If you want unit ready to use with plug/receptacle designed for dust collection motors, check out the PSI Long Ranger or iVac remote switch You can find reviews and discussion threads on these devices, and other solutions in forums too. Best Luck. -- If it wasn't for bad luck, I wouldn't have no luck at all, - Albert King - Born Under a Bad Sign released 1967 |
#5 posted 02-22-2021 11:14 PM |
I have used that sort of switch on a Harbor freight 2hp dust collector for years. Picked mine up at Home Depot. -- John |
#6 posted 02-22-2021 11:28 PM |
I am using the I socket# auto switch which will turn the vac on when I turn on my ROS. It has been flawless for the past 3 years. |
#7 posted 02-22-2021 11:34 PM |
I bought an inexpensive remote and switch at Home Depot last year to use with my HF Dust Collector…. That DC kicks a bit of amperage when it starts and fried the switch within a few weeks. So, I bit the bullet and invested in an i-Vac remote. It’s been flawless since. But, that’s a dust collector with a bit more powerful motor and a heavier kick, electronically, when it starts. I’d say you’d be fine with a cheapo remote and switchable outlet for a shop vac. -- John F. SoCal transplant, chewer uppper of good wood |
#8 posted 02-22-2021 11:41 PM |
Thanks for the information guys – if I am following correctly, it sounds like in a bad scenario, it’s this whichever-i-buy outlet that would fail, not the shop vac? Or could an underpowered/cheap outlet actually damage my ridgid vacuum? |
#9 posted 02-23-2021 12:03 AM |
The vacuum should be immune to most anything electrical, but if you try a low-buck switch, keep it somewhere you can see it in case the smoke gets let out. |
#10 posted 02-23-2021 12:22 AM |
In my experience, the weakest link goes out first. If the switch is the weakest link, the contacts inside are going to arc and build up “carbon” that keeps from making a connection. I’ve seen this quite a lot and have even opened them up and filed/sanded the contacts clean to extend the life. |
#11 posted 02-23-2021 04:52 AM |
I bought one of the remotes for Christmas lights over five years ago. It was on clearance at Lowe’s for less than $2. It has worked with my Ridgid “5HP” shop vac ever since. -- Joe | Spartanburg, SC | "To give anything less than your best is to sacrafice the gift." - Steve Prefontaine |
#12 posted 02-23-2021 04:57 AM |
Damn that price is nice! |
#13 posted 02-23-2021 11:26 AM |
You often find those switches on sale around Christmas, I keep several (of the same brand) in the shop in case the one I’m using fails. -- Our village hasn't lost it's idiot, he was elected to congress. |
#14 posted 02-23-2021 12:04 PM |
Exactly! I bought every one they had. Have a few to family members and saved a few to use as spares. -- Joe | Spartanburg, SC | "To give anything less than your best is to sacrafice the gift." - Steve Prefontaine |
Forum | Topics |
Woodworking Skill Share
13194 |
Woodturning
2812 |
Woodcarving
569 |
Scrollsawing
416 |
Joinery
1892 |
Finishing
6339 |
7903 |
32747 |
CNC Woodworking
329 |
Hand Tools
6450 |
Jigs & Fixtures
1804 |
Wood & Lumber
7275 |
1632 |
Focus on the Workspace
2630 |
1272 |
Woodworking Trade & Swap
5412 |
LumberJocks.com Site Feedback
2396 |
Coffee Lounge
9656 |
