Flush front drawers
Forum topic by willhime posted 02-19-2021 05:59 PM 690 views 0 times favorited 8 replies Add to Favorites Watch
View willhime's profile
willhime
186 posts in 2704 days
02-19-2021 05:59 PM
Topic tags/keywords: jig question resource tip trick bandsaw scroll saw tablesaw sander router finishing joining sanding scrollworking
I got roped into building a desk for a family member and this is the one they picked. I’ve been trying to figure out how it was made and my first guess was similar to a bandsaw box.
After thinking it over though and looking at the picture it seems like another method was used since there’s no seam where the front would be sawed off then re-glued. Now my theory turns to either bandsaw then scroll saw to cut the top corners, or… cnc with an 1/8” end mill bit.
As far as the joint from the front panel to the surface is concerned, maybe there’s a very deep cut rabbet on the surface underside leaving only a 1/16 to accept the face panel ?
Any theories are welcome
-- Burn your fire for no witness
8 replies so far
View bilyo's profile
bilyo
1376 posts in 2267 days
#1 posted 02-19-2021 06:20 PM
That is a very hansom design. And maybe not as difficult as you imagine. It is quite possible that the edges are mitered so that the seam is right in the corner so that it is not obvious. Even if that one is not made that way, it would be a good way to do it. When I zoom in, I note that they didn’t do very well in matching the grain of the drawer fronts with the rest of the desk. They lose points in my book. ;>)
View Loren's profile
11234 posts in 4813 days
#2 posted 02-19-2021 07:00 PM
I suspect the front and back are solid while the top and sides are veneered. I don’t know if that answers your question.
View pottz's profile
pottz
18881 posts in 2149 days
#3 posted 02-19-2021 07:25 PM
That is a very hansom design. And maybe not as difficult as you imagine. It is quite possible that the edges are mitered so that the seam is right in the corner so that it is not obvious. Even if that one is not made that way, it would be a good way to do it. When I zoom in, I note that they didn t do very well in matching the grain of the drawer fronts with the rest of the desk. They lose points in my book. ;>)
- bilyo
+1 i dont think it was cut from a single piece of wood,and being light colored most people wouldn’t even notice.
View SMP's profile
SMP
4459 posts in 1070 days
#4 posted 02-19-2021 07:53 PM
Kind of weird that it wasn’t cut from a single piece, that would be more traditional. Maybe these are mass produced and the drawers interchange so when they are put together they just grab random drawer fronts
bilyo
#5 posted 02-20-2021 11:06 PM
+1 i dont think it was cut from a single piece of wood,and being light colored most people wouldn t even notice.
- pottz
I’m not arguing the point. It could be all veneered. I’m just wondering what makes you so sure.
Craftsman on the lake
3871 posts in 4602 days
#6 posted 02-20-2021 11:48 PM
The grain of the drawers is not the same as the desk so the drawers were made separately I think. Looks like the top and edge are a little bit different colors too. I’ll bet this desk is really a top with a separate edge and the drawers were made separately. So, it’s a box, probably an open bottom too.
pottz
#7 posted 02-21-2021 12:14 AM
- pottz
I m not arguing the point. It could be all veneered. I m just wondering what makes you so sure.
- bilyo
well as you said the grain doesn’t match,but it could also be veneered.
View LeeRoyMan's profile
LeeRoyMan
1954 posts in 892 days
#8 posted 02-21-2021 03:04 AM
I see it as a solid wood frame, mitered at the corners, (I can’t see the corners so it’s only an assumption)
with a top rabbeted into the frame and the covered with veneer.
Obviously cutouts were made for the drawers, and then separate drawer fronts with no attempt to match the grain..
Edit: Cutout for drawers were probably routed out before the frames were assembled.
