Planer issues
Forum topic by DoobieNC posted 02-13-2021 04:03 PM 370 views 0 times favorited 4 replies Add to Favorites Watch
View DoobieNC's profile
DoobieNC
3 posts in 70 days
02-13-2021 04:03 PM
Topic tags/keywords: planer
While using my new planer, my dust collection backed up causing the planer to overheat. There was a spark from the motor and it would not cut back on. I cleaned out all of the debris and then it would cut on but the circuit on the planer would trip shutting it down. I checked the brushes on the motor and one showed some signs of overheating. I cleaned it up and now when you cut it on, it will start up but trip again after about 2 seconds. Do you think new brushes would fix the issue or tear deeper into the motor?
-- Derek, North Carolina
View pintodeluxe's profile
pintodeluxe
6347 posts in 3874 days
#1 posted 02-13-2021 04:52 PM
If this is really a new planer, then just take it in for repairs. If it’s new to you, but actually a used tool, then it’s a reasonable project to tear into.
Also, please tell us the make and model so we can give educated answers for you.
I’ve had this problem before, and it was a actually the overload protector switch on the planer that was bad. They are thermal overloads and don’t always survive being tripped.
Best of luck with it.
View Lazyman's profile
Lazyman
6946 posts in 2448 days
#2 posted 02-13-2021 05:17 PM
I bogged down a table saw once and tripped its built-in breaker. After that it would trip with only minor load. I read that these breakers sometimes get damaged when severely overloaded, causing them to trip too easily after that, and replacing the breaker fixed the problem.
If it is new, I would probably looking into warranty service but replacing the breaker is usually a cheap and easy fix.
DoobieNC
3 posts in 70 days
#3 posted 02-14-2021 01:52 AM
The planer is a WEN 6552. I called customer support thinking I would buy new brushes and start there. After a discussion with the tech, a new motor is being sent to me.
View Aj2's profile
Aj2
3777 posts in 2859 days
#4 posted 02-14-2021 03:06 AM
Dust collection is under sized. Or from horrible fraud aka ( harbor freight)
Its Kinda unfair to blame the planer manufacturer
-- Aj
