Angle of Skew
« back to Woodturning forum
Forum topic by lalkie posted 02-11-2021 03:28 PM 546 views 0 times favorited 10 replies Add to Favorites Watch
View lalkie's profile
lalkie
31 posts in 2035 days
02-11-2021 03:28 PM
Does anyone know what the left to right angle of a skew is? I am in the process of building
a sharpening jig to sharpen my lathe tools and wanted to know the best angle to tilt the
skew on my belt sander. Larry Thanks
-- Thanks Larry
10 replies so far
View Lazyman's profile
Lazyman
6932 posts in 2442 days
#1 posted 02-11-2021 03:37 PM
Mine vary between 25° and 15° off 90° (65-75°). I prefer the 25° for most things.
View TheDane's profile
TheDane
5952 posts in 4718 days
#2 posted 02-11-2021 03:44 PM
Here’s a link to Alan Lacer’s instructions for sharpening his skews: https://www.hamletcrafttools.co.uk/alanins.html
BTW … I seldom take my skews to the grinder. Once they are shaped per Alan’s instructions, I just touch them up with one his diamond hones.
View HokieKen's profile
HokieKen
17296 posts in 2193 days
#3 posted 02-11-2021 04:12 PM
As suggested above, there is no fixed skew angle. You can make it essentially whatever you want. I grind mine in the same range as Lazyman.
-- I collect hobbies. There is no sense in limiting yourself (Don W) - - - - - - - - Kenny in SW VA
View SMP's profile
SMP
3803 posts in 960 days
#4 posted 02-11-2021 04:38 PM
A skew for what? Which tool? A normal chisel isn’t critical. If you are also sharpening plane irons then those skews are more critical
View OSU55's profile
OSU55
2774 posts in 3044 days
#5 posted 02-13-2021 01:43 AM
Follow the Alan Lacer instructions linked above. The curved skew is definitely the way to go. No jig is needed, only a platform to get the bevel angle where you want it. Lacer’s instructions will provide ~20 deg bevel. Have fun honing a flat bevel vs hollow ground.
View Wildwood's profile
Wildwood
2954 posts in 3189 days
#6 posted 02-13-2021 12:19 PM
If you don’t want to waste a lot steel using diamond stones versus power equipment is the way to go! Yes sticking with factory grind for learning the tool and using will save time & money. If factory grind too difficult going to curved or round skew might make life easier.
“Alan Batty’s Notes,” on pages two & three “The Skew,” shows conventional skew grinds and explains different grinds for the skew and his compromise of 40 degrees.
https://www.lumberjocks.com/wildwood/blog/123889
This reference covers both conventional and curved grinds.
Sharpening Handbook
Good luck with it!
-- Bill
View John Jardin's profile
John Jardin
98 posts in 695 days
#7 posted 02-13-2021 01:08 PM
Bill,
Thank you for the “Alan Batty’s Notes,” What a great resource for turning.
lalkie
#8 posted 02-14-2021 03:00 AM
Thanks for the advice. I am in the process of designing a jig to sharpen my lathe chisels on a belt sander. It is working pretty good so far. It needs tweaking but I am getting close. I will probably go with the 65 to 75 degrees. Larry
-- Thanks Larry
View SMP's profile
SMP
#9 posted 02-14-2021 04:45 AM
BtW, just went to check my skew and it is at 15 degrees from
The factory
Wildwood
#10 posted 02-14-2021 02:40 PM
Guess this link didn’t work yesterday and not working today:
https://www.sharpeninghandbook.info/ww-skewchisel.html
Nice to know info on other turning tools
If click on same link “Lathe Tools,” more nice to know info.
https://sharpeninghandbook.info/index-ww.html
Will see lot of references to Tormek sharpening system & accessories depending upon what you’re looking at on this site.
My take on bevel angles will vary with the turner and what they become accustomed too. Whether they free hand or use a jig sharpening their tools those angle don’t vary much. One or two degrees not going to make a world of difference.
Sorry for wasting your time!
-- Bill
