Does this exist? - Spray-pencil?
Forum topic by totalrewind posted 02-09-2021 02:37 AM 328 views 0 times favorited 2 replies Add to Favorites Watch
View totalrewind's profile
totalrewind
64 posts in 3354 days
02-09-2021 02:37 AM
Topic tags/keywords: question woodburning
If you’re woodburning with a stencil, the usual process is you grab a pencil and trace around the pattern. Then when you’re done, you simply erase the lines.
Not too bad, but the thing is I have a lot of them to do.
Is there such a thing as a pencil (or some other erasable material) in a spray can? That way I can just spray over the stencil and move on.
Can’t use regular spray paint because it won’t erase. Can’t use graphite or chalk dust because it will just blow away. Is there something in between in terms of permanence?
-- For more projects (not just woodworking) check out my project blog at http://theheadlesssourceman.wordpress.com
2 replies so far
View Madmark2's profile
Madmark2
2655 posts in 1670 days
#1 posted 02-09-2021 03:33 AM
Copier toner. Laser (not inkjet) toner is thermally activated. Print your pattern in reverse on laser. Lay printed side down on wood and use HOT iron to transfer pattern.
Thick lines transfer better. Surface should be sanded smooth first.
-- The hump with the stump and the pump!
View Rich's profile
Rich
6840 posts in 1671 days
#2 posted 02-09-2021 04:16 AM
Madmark2 has your answer. Good advice.
