Finishing a Honey Dipper
Forum topic by Redoak49 posted 02-05-2021 10:18 PM 752 views 0 times favorited 4 replies Add to Favorites Watch
View Redoak49's profile (online now)
Redoak49
5416 posts in 3269 days
02-05-2021 10:18 PM
I have turned a couple of Honey Dippers. One from Maple and another from Cherry and I would like to put a protective finish on them. I was thinking of either mineral oil or Beeswax. Anyone have a suggestion?
View LesB's profile
LesB
3134 posts in 4723 days
#1 posted 02-05-2021 11:37 PM
I think you need to seal them against intrusion from not only the the honey but the water/soap that will be used to clean the honey off…... so I would use a poly finish possibly even better a salad bowl finish from General or Behlen’s. They are infinitely washable with no re-applying needed like an oil finish.
If that is not what your are looking for then I would apply a couple of coats of processed walnut oil (Mahoney’s) and when it is cured dry 48 or so hours, use a paste wax as a top coat. Mahoney’s actually sells those to as a combo on Amazon.
-- Les B, Oregon
View SMP's profile
SMP
4946 posts in 1186 days
#2 posted 02-06-2021 02:07 AM
Pure tung oil and citrus solvent works well
View Wildwood's profile
Wildwood
2959 posts in 3415 days
#3 posted 02-06-2021 01:48 PM
Just mineral oil will work I like finishing on the lathe. Some folks like using bees wax & mineral oil mix.
Both methods are food safe and easy to reapply if needed.
-- Bill
View Lazyman's profile (online now)
Lazyman
8182 posts in 2668 days
#4 posted 02-06-2021 02:07 PM
I would probably use a BLO and beeswax mix. Tried and Trues original wood finish is one that has both and no other additives, like heavy metal driers that some BLO mixtures have.
