Warped Door
Forum topic by skcj213 posted 02-03-2021 09:39 PM 308 views 0 times favorited 3 replies Add to Favorites Watch
View skcj213's profile
skcj213
30 posts in 2522 days
02-03-2021 09:39 PM
If this is an inappropriate post, go ahead and delete it. I am refinishing an antique china cabinet. It has 2 doors on the bottom portion that are about 12” x 16”. One of them is severely twisted. When closed, the top corner is inboard about 1/2” more than the bottom. Any suggestions on how I could straighten it out?
3 replies so far
View menuisierJC's profile
menuisierJC
18 posts in 91 days
#1 posted 02-04-2021 09:59 PM
I have not tried this on a cabinet door, but I have used water to dampen wood and then clamped it under pressure while it dried (poor man’s steam bending). You have to overbend because there will be springback.
Depending on the glue and other variables, this might work or it might make a real mess. My reason for optimism is that you only have 1/2 inch over 12-16 inches that you need to move.
-- Jeffrey
View Aj2's profile
Aj2
3769 posts in 2855 days
#2 posted 02-04-2021 10:57 PM
I would spend my time adjusting the hinges to take out some of the misfit on the case. If the doors were built with a twist a twist shall remain
Good Luck
-- Aj
View Rich's profile
Rich
6779 posts in 1646 days
#3 posted 02-05-2021 04:35 AM
Without seeing it, I can’t say for sure, but if a corner of the door is “inboard”, consider adding stops. That will keep it from bending into the cabinet. It’s not a perfect solution, but it would keep the faces of the doors flush.
