02-01-2021 12:04 AM
Topic tags/keywords:
dust collection
I just upgraded my dust collection system:
- replaced home-made Thien Baffle with Super Dust Deputy XL
- replaced the main trunk line of 4” PVC with 6” metal pipe
I’m no expert, but I thought I’d pass on a few things I learned:
- I went with metal because 6” PVC is expensive, heavy, and I don’t have access to a lot of fittings.
- Unless you know you have a good, sharp pair of tin snips, get some new ones.
- When I use PVC, I can put together with minimal attention to the joints because they are pretty close to dust tight just from a friction fit. I often put in one screw just to keep it together until I’ve decided I like the layout, then I’ll put on some alumininum tape or whatever, but works well without much work.
- Assembling the metal pipe runs in the same manner doesn’t work at all. I put in three screws into every joint—one just gives you a joint with huge gaps. Then, putting it together is only half the battle—sealing up all the joints is the second part of the installation.
- If I had to do it over again, I would seal as many joints as possible before assembling (mine is on ceiling).
- I thought tape was the best thing, but I ended up only using if for the long flat seams on the tubes. For all other joints, I would apply duct mastic, cover the joint with mesh fiber tape, and then dover the tape with dust mastic. When dry it is an air tight, solid connection.
- I didn’t realize how many seams were in every connecting piece. All those needed to be sealed.
Maybe everybody knows these things—I didn’t. Now, it is done. I think it is better, but I haven’t had much time to test it out. We’ll see.
13 replies so far
#1 posted 02-01-2021 01:47 AM
What kind of metal pipe did you use? HVAC pipe from the hardware store?
Would you post a few pictures? I’m particularly interested in your Y-joints and the main connection to your dust collector.
-- Jeffrey
#2 posted 02-01-2021 01:58 AM
Yes, Borg metal duct.
I’ll try to take some pics, but not sure I want to show them!
Would you post a few pictures? I m particularly interested in your Y-joints and the main connection to your dust collector.
- menuisierJC
#3 posted 02-01-2021 02:05 AM
I paint 2 coats of duct sealer down the length of the joint. And also on the 90’s after adjustment and installation. As short of screws as possible to avoid collect long stringy shavings. 26 or even some 24 guage when 26 was out of stock. I use 5” with my 2 hp collector.. I buy the long 90’s, but weld up my own Y fittings to order with a spot welder, then seal with more duct sealer. There are online apps with patterns for cutting the parts for a Y, or a double Y. A great system, and being steel, no shock hazzard.
#4 posted 02-01-2021 02:08 AM
I am in the process of same. That darn spiral duct is expensive. I did not use HVAC duct for the trunk as I have been warned, if you forget and all your gates are closed, you can collapse the duct. Anyway, 6 inch all the way to the TS and BS. Splitting a 4 for the sanders. Dropping a 4 inch right over the table that I can move between the router and TS blade guard. I’ll have a 4 inch port I can put my planer and jointer on. They’re on wheels.
I am a big fan of the foil duct tape. Unlike Duck tape, it is suitable for ducts as the glue does not dry out like the rubber glue does. Easier to re-do as it does not get hard like duct sealing paste or even caulk. Found my self-clearing blast gates leak quite a bit, so they will get a flap of poly tape.
Just added a ClearView cyclone to my Fein vac. Super impressed. Found adapters for my pad sanders and made one from a bit of sink trap PVC for my old Makita belt sander.
Bill Pentz says it really takes a 5 HP, and that needs at least an 8 inch trunk, but I don’t have the power. I’ll see how I do with the 1 3/4. If it is OK, then on will go with the 6 inch Oneida. If not, I’ll get a new 3 HP system.
The hard part is not the DC system, it is the various ideas I have for focusing the airflow through the TS. I was looking at the trunnion and it looks very hard to do any of my crazy ideas except the ramp.
I cut my ducts with my angle grinder. Much easier.
#5 posted 02-01-2021 02:09 AM
Even HD has 45 degree Y joints. And they have a nice long taper 6 to 4 reducer.
#6 posted 02-01-2021 11:52 AM
I guess I went in a different direction. For me, it e seems like a real pain to seal the metal duct. I used 6” DWV which is not heavy and joints seal very well.
I have a 5 hp cyclone and ran 6” pipe and have very good flow and suction.
#7 posted 02-01-2021 01:42 PM
- Redoak49
Help me out here what is DWV?
#8 posted 02-01-2021 01:45 PM
DWV is Drain, Waste, and Vent. That’s what I used for my 4” duct. It is much lighter than schedule 40 since it is not made to handle pressuized water. In 6” it is not overly heavy, but much heavier than metal duct.
#9 posted 02-01-2021 04:17 PM
Did you lose suction at the tools when you went from 4” to 6” ?
-- Mike from Lansdowne, PA
#10 posted 02-01-2021 05:27 PM
I have a 2HP cyclone and went with 6” SDR for the straight, ceiling mount drop trunk (about 15’ long) and used some of the PVC “Y’s” for branches. You are correct about the $$, but I like the ability to dry assemble and get tight joints.
The rest of the system is 6” Borg HVAC duct (the stuff with the lengthwise seam). Nice and light weight but does require the obligatory miles of foil tape. The bends are all done with the adjustable swivel “elbows” since I have some compound angles needed for routing. Nary any signs of collapsing when I slam shut the last blast gate even though the HVAC duct is thin.
#11 posted 02-01-2021 05:33 PM
- BigMig
As long as you have a big enough blower you will gain air flow/cfm/volume of air through the pipe. The volume of air you can move is what matters, not suction. More air flow pulls more dust in with it.
Yes, there is more involved but that is generally speaking.
-- Jeff Horton * Kudzu Craft skin boats* www.kudzucraft.com
#12 posted 02-01-2021 05:57 PM
- menuisierJC
Here’s a pic of a wye that is on the ceiling branching off to 4” pvc drop.
#13 posted 02-01-2021 06:10 PM
I originally had 6” spiral duct and split duct HVAC 26gauge metal piping. My recommendation for anyone going down this path….contact your local HVAC distributor, if you have one in your local area. Just about same price tag of BORG stores but with the lower gauge. So win-win. I ditched all my metal ducting and went 6” S&D plastic. Got tired of the paper cuts :) And not being a HVAC professional, my crimps & joints ended up being in the 4.5”-5” circumference on certain connections (especially, Y’s). I went all S&D because can mold, bend, custom fit with heat gun for that super tight friction fit. Total 6” footage would be around….60’ and then transition to some 20’ 4” pipe.
Forum |
Topics |
Woodworking Skill Share
Your woodworking skills are displayed for several lifetimes in each project. Have you had to compromise your project...
13248 |
Woodturning
On the lathe, by the lathe: do you have questions? frustrations? tips? This forum is for all the woodturners out there.
2831 |
Woodcarving
Relief, 3D, chip-carving, whittling; carving knives, chisels, pocket-knives, power tools. If you are a carver or want...
579 |
Scrollsawing
Intarsia, fretwork, intricate design cutting and more! This forum is for scrollsawers: share your tips, ask questions...
417 |
Joinery
Have a question? a tip/strategy to share? a challenge, perhaps? Share your "joinery" discussion here.
1914 |
Finishing
The finish, whether paint, wax, stain, or something else, can make or break a project. What are your tips and questio...
6404 |
Looking for information on designing your projects? Having difficulties reading project plans? Looking for help with ...
7947 |
Are you unsure of which tools, or hardware, you need, or which brands to buy? Investing in tools and hardware can be ...
32960 |
CNC Woodworking
Questions and answers about CNC machines, tooling, best practices, and projects.
335 |
Hand Tools
Wood, your hand tools, you and a little know-how. Share your questions, tips and strategies for the use and maintenan...
6489 |
Jigs & Fixtures
Using a jig is like having a couple extra hands helping out. Show us your jigs, share your tips, strategies and, of c...
1825 |
Wood & Lumber
Different wood requires different woodworking strategies - from cutting to finishing. Share your tips and challenges ...
7312 |
Before you pick up those woodworking tools, take the time to ensure your safety in the shop! Eyes, ears, fingers, and...
1647 |
Focus on the Workspace
Are you looking for or do you have tips to share regarding the workshop? Storage, equipment placement, efficiency, an...
2644 |
If you are selling your work, then you have entered a woodworking dimension with added complexity and stress. If you...
1273 |
Woodworking Trade & Swap
All of us are holding onto treasure in our shops, that we either don't need, don't want, or could part with if presen...
5437 |
LumberJocks.com Site Feedback
Connect with the Website Gurus and tell us what you are thinking, suggestions, problems, functionality issues, and so...
2401 |
Coffee Lounge
Need a break from all the standing and wood dust? Chat with your Forum Friends about their projects, their life, thei...
9685 |
