Forum topic by Flyarmy | posted 01-27-2021 03:15 PM | 633 views | 0 times favorited | 27 replies | ![]() |
Topic tags/keywords: wood turning wood lathe Hey guys, I am new to this forum, and i wanted some advice. I am interested in getting in to wood turning, bowls, table legs etc, but haven’t done it since 8th grade wood shop. I saw a used one for $500, and it’s a Craftsman 21750 15 in. Variable Speed Wood Lathe and comes with 8 relatively new tools. No duplicator or copy attachment. is this worth it, (stipulating it is in good working condition)? Or would ya’ll suggest i get a brand new one from Harbor Freight, or other stores. I really don’t want to spend more than $500, any suggestions/advice is appreciated. |
27 replies so far
#1 posted 01-27-2021 04:12 PM |
Not familiar with that model, but my guess is anything is better than HF. Is it belt change variable? If electronic speed control, parts may be hard to find. |
#2 posted 01-27-2021 05:36 PM |
Thank you for the quick reply ibewjon, i appreciate it. I m pretty sure is is variablle by belt, not by electronic speed control switch. I was considering a Grizzley form the website Offerup, but i sat on the fence too long and someone bought it. below is a link to the Craftsman. |
#3 posted 01-27-2021 05:54 PM |
As it turns out, it is controlled by a knob, not by belt, furthermore, Craftsman no longer makes the lathe so parts would be hard to get, if not impossible. |
#4 posted 01-27-2021 06:42 PM |
Have you checked Facebook Marketplace to see what’s available there. Highland Woodworking (Atlanta, Ga area) has a Rikon 70-1218VS on sale for $349.99 https://www.highlandwoodworking.com/rikon-12-inch-vs-midi-lathe-70-1218vs.aspx Rikon has a 5 yr warranty. Then you could start out with an inexpensive set of turning chisels. Penn State Ind. is another way to keep the price down. They always seem to have sales and starter kits. https://www.pennstateind.com/store/mini-lathes.html As you may know, the lathe is not the really the expensive part. It’s all the accessories that add up. |
#5 posted 01-27-2021 07:06 PM |
It would push $700 for the lathe, but i really like my Rikon 70-220 VS (12” swing, electronic variable speed in 3 ranges, over 3” of quill travel—handy if you turn an ink pen or 300!!) |
#6 posted 01-27-2021 09:39 PM |
Hey Woodendreams, thank you very much for the information as well as the links, i have never heard of either of those websites/companies. Pennstate has the 12 inch Midi lathe, and I like it, it offers the option of getting an extension that would allow me to turn legs or spindles that are 40” from what I can see. https://www.pennstateind.com/store/KWL-1218VS.html I believe i am going to go that route, what are your thoughts? and out of curiosity, what is a “midi” lathe, I have always just heard wood lathe or metal lathe? |
#7 posted 01-28-2021 12:00 AM |
That Craftsman lathe has a Reeves drive and is a discontinued model with no parts or support … run, don’t walk. -- Gerry -- "I don't plan to ever really grow up ... I'm just going to learn how to act in public!" |
#8 posted 01-28-2021 12:13 AM |
Thanks Thedane, after seeing the other options for new ones, I am going that route. I am more than likely getting the 1218vs listed above from PennState. I am guessing it will let me turn any type of hardwood for bowls, as well as spindles, table legs, and even a pen, what do you think? |
#9 posted 01-28-2021 12:15 AM |
That Craftsman lathe has a Reeves drive and is a discontinued model with no parts or support … run, don t walk. They are also asking for what the thing could be purchased new for… I’ve also seen that lathe bundled with a bunch of other stuff, including a duplicator, for less than $700 new with warranty. Certainly not worth it IMO. I would also not let speed change methods be a deal breaker… a 4 or 5 speed manual stepped lathe is just as usable as a variable speed one. It only takes a few seconds to swap pulley steps, and over the life of a project, you may only need to change the speed once – maybe twice – so it’s not that big of a deal for me. Pulleys also last a very, very long time. I’ve only paid as much as $500 for a lathe once, and still think I overpaid. My normal limit is $150 and average is around $50. You would be surprised what $150 can get you if you are patient. Cheers, -- Brad in FL - In Dog I trust... everything else is questionable |
#10 posted 01-28-2021 01:43 AM |
Thanks Brad, I appreciate the input. As for the variable speed, I don’t feel like I have to have it, it was just what came with the 12” version I saw on PennState website. Are you saying I can find a good lathe for $150 if I am patient? Can you tell me what brands/models you would trust at that price point? Thanks in advance for your time and advice. That goes for all you guys who have been helping me. I am glad to be a part of this forum and look forward to learning a lot and enjoying a new hobby. |
#11 posted 01-28-2021 03:18 AM |
Here is a little info on lathes, Mini, vs. Midi, vs. full size I think you are on the right track starting with a Midi. The 12” swing makes a good bowl, a great vase, and everything smaller. Plus as you mentioned a bed extension for table legs. Also, before you buy anything. Contact your local club. You will learn tons of good info, and maybe even find a great deal on used equipment. https://www.atlantawoodturnersguild.org/ and the rest of the web search here, Good Luck, and Welcome to LJ, -- John |
#12 posted 01-28-2021 12:22 PM |
That was a great article and education about the different types of lathes John, thank you. Also, it never occurred to me that there would be a group of people in my area that get together to talk about wood projects, Thank you for the links. I looked up the one that you listed first, and it’s a couple of hours away from me in light traffic, but after looking at the full list you sent, i found one that meets in Northwest GA which is much closer, so i will link up with them. Thank you for the links and support. |
#13 posted 01-28-2021 05:06 PM |
Hey guys, another question, why would i want a chuck like this: If I have a faceplate like this: Don’t they both do the same thing? |
#14 posted 01-28-2021 06:49 PM |
Don’t they both do the same thing? Yes and no. Yes – they both hold a work piece so it can be turned – but they do it in different ways. Cheers, -- Brad in FL - In Dog I trust... everything else is questionable |
#15 posted 01-29-2021 05:23 PM |
The chuck has a lot more flexibility. It can be used for both bowl and spindle turning and for bowl turning will allow you to hold a bowl for hollowing without making mounting holes or using something like double side tape for mounting. For example, you may start by mounting on a faceplate to shape the bottom, including adding a tenon or recess that the chuck can grab. You turn it around and grab the tenon or recess with the chuck. Of course then you usually have to then remove the tenon afterwards. You can do all of these things without a chuck but it is just easier with one. BTW, I would probably go with one of the name brand chucks rather than that Wen you linked to. Unless you can verify that other jaws are available, something like a Nova will be a better long term investment and make it even more useful, especially if you upgrade to a larger lathe down the road. -- Nathan, TX -- Hire the lazy man. He may not do as much work but that's because he will find a better way. |
Forum | Topics |
Woodworking Skill Share
13194 |
Woodturning
2812 |
Woodcarving
569 |
Scrollsawing
416 |
Joinery
1892 |
Finishing
6339 |
7903 |
32746 |
CNC Woodworking
329 |
Hand Tools
6450 |
Jigs & Fixtures
1804 |
Wood & Lumber
7275 |
1632 |
Focus on the Workspace
2630 |
1272 |
Woodworking Trade & Swap
5412 |
LumberJocks.com Site Feedback
2396 |
Coffee Lounge
9656 |
