Forum topic by Karda | posted 01-26-2021 11:35 PM | 324 views | 0 times favorited | 13 replies | ![]() |
Hi, when I turn handles for socket chisels my cone center splits the tapered end that goes into the socket. Turning starts ok but as I turn the socket end down enough pressure on the center to hold the blank will split the end. At this point the socket is about .25” tapering up to.50” I tried the center that came with the lathe and there is not enough room to work any ideas thanks |
13 replies so far
#1 posted 01-27-2021 12:00 AM |
Use less pressure. Wax the cone. Check the bearing. The cone should slip, not bind. -- The hump with the stump and the pump! |
#2 posted 01-27-2021 12:07 AM |
it is noy binding it is spitting and that happens when I tighten the tail stock. in order to fit to the chisel I have to remove it from the lathe and remount it until I get it right, in the process of doing that the blank splits |
#3 posted 01-27-2021 12:39 AM |
That’s why I don’t use a cone center on spindles … you are basically driving a wedge into the end grain. -- Gerry -- "I don't plan to ever really grow up ... I'm just going to learn how to act in public!" |
#4 posted 01-27-2021 12:43 AM |
if you have a chuck, chuck it up and turn the taper with the cone centered on it. Check the size, then bring the cone up again. Rpeat until you have your fit. Do no apply too much pressure. The cone is supposed to have just enough pressure to keep it steady if you get a catch. You don’t have to remove it from the chuck until done…......... Jerry (in Tucson) -- Jerry (in Tucson) www.woodturnerstools.com |
#5 posted 01-27-2021 12:45 AM |
Pilot the cone hole instead of forcing the tip into the end. Use, say, a 1/4” dia bit about 3/8” deep. If you have to crank the hell out of it you’re doing it wrong … -- The hump with the stump and the pump! |
#6 posted 01-27-2021 12:57 AM |
I’m far from a turning pro but a cupped live center with spring loaded center point works well for me on these although I haven’t gone as small as 1/4” on the ones I’ve done. I think the cup on mine is 5/16”. Not my picture. -- Darrel |
#7 posted 01-27-2021 12:57 AM |
thanks for the pilot tip didnt think of that. I would like to use my chuck but I don’t have small jaws, mine will only close to a little under 1 3/4” |
#8 posted 01-27-2021 02:38 AM |
I use one of these Cup Center Converters on my large cone center when I am worried about splitting or even if I just don’t want the tip to go in too deep. It has magnets embedded that hold it on and works on a 60° cone. -- Nathan, TX -- Hire the lazy man. He may not do as much work but that's because he will find a better way. |
#9 posted 01-27-2021 02:47 AM |
Ive one like that but I was stupid and got one with no magnets, I tried that but with that on the cone I can’t find the center |
#10 posted 01-27-2021 03:00 AM |
I use an awl to mark the center and it sticks out just enough to be able get the point into marked center. It is even cheaper at PSI, though I am not sure what their shipping costs are. -- Nathan, TX -- Hire the lazy man. He may not do as much work but that's because he will find a better way. |
#11 posted 01-27-2021 04:28 AM |
yea that is the one I should have got but I ordered a bandsaw blade from Packard so I got that as well. I store it on a magnet on my lathe but the steel will stick to a magnet but will not become magnetized. I know how to make a center but with that cup on the cone i can’t see the hole in the blank, the cup is cylindrical not tapered on the outside |
#12 posted 01-27-2021 02:24 PM |
Try putting the cup on a strong magnet and tap it several times with a hammer. Sometimes that will give steel objects a little temporary magnetism. It might be just enough to hold it in place. Another thing that you can try is to gunk up your center so that the cone sticks. I rubbed a thick coat of bees wax on it once and the residue makes it sort of hard to pry the cup from the cone now. If you have some some pine that is oozing some resin, you can try that too—anything sticky. -- Nathan, TX -- Hire the lazy man. He may not do as much work but that's because he will find a better way. |
#13 posted 01-27-2021 04:37 PM |
Mike, what is the diameter of the opposite end at the spindle?? ......... Jerry (in Tucson) -- Jerry (in Tucson) www.woodturnerstools.com |
Forum | Topics |
Woodworking Skill Share
13199 |
Woodturning
2814 |
Woodcarving
569 |
Scrollsawing
416 |
Joinery
1893 |
Finishing
6345 |
7906 |
32761 |
CNC Woodworking
330 |
Hand Tools
6453 |
Jigs & Fixtures
1804 |
Wood & Lumber
7276 |
1633 |
Focus on the Workspace
2632 |
1272 |
Woodworking Trade & Swap
5417 |
LumberJocks.com Site Feedback
2396 |
Coffee Lounge
9658 |
