Forum topic by Woodchuckswife | posted 01-26-2021 12:15 PM | 398 views | 0 times favorited | 10 replies | ![]() |
Topic tags/keywords: scroll saw lite Where to buy a new mag lite my old one just burnt up, I turned it on and it started to smoke and crackle. I look at one on RBI , and could not beleve the price since I bought the last one. |
10 replies so far
#1 posted 01-26-2021 12:48 PM |
Kind of obsolete with newer LED and Li batteries, unless you are a watchman and need a Billy club. There are some newer designs and equal in quality. Search Amazon/WalMart/etc for “high brightness flashlight” This is one of many similar to mine. ( A Semlos) I see one that is actually 90,000 Lumens! Most use standard Li cells, so if a battery goes bad, they are replaceable. |
#2 posted 01-26-2021 01:15 PM |
Yeah, if you don’t need it as a weapon, the little LED ones are awesome, and dare I say… that Harbor Freight has some pretty good inexpensive ones, regularly on sale or with a coupon, I think I have a half dozen around the house just because they are handy, and usually only $5 -- I've decided 1 mistake is really 2 opportunities to learn.. learn how to fix it... and learn how to not repeat it |
#3 posted 01-26-2021 01:42 PM |
When I need a flash light, I need LIGHT! I find the switches and contacts in the cheap ones to oxidize so when you need the light, it won’t work. Around the house at night, my wife used an old Ridgid light that came with a drill. I have an old Makita from a kit that works too, but these are just “flashlight bright” not the “Oh my god” bright I want when I really need to see something. It took about three tries ot get a headlight bright enough to actually use. |
#4 posted 01-26-2021 02:29 PM |
I am not talking about a flash lite ,I need one that fits on a RBI scroll saw . Chuck |
#5 posted 01-26-2021 03:44 PM |
Do you mean a magnetic mount light? -- Nathan, TX -- Hire the lazy man. He may not do as much work but that's because he will find a better way. |
#6 posted 01-26-2021 03:58 PM |
Something like this? https://www.leevalley.com/en-ca/shop/tools/workshop/lighting/71189-magnetic-mount-led-work-light?item=15J7701 -- Darrel |
#7 posted 01-26-2021 04:34 PM |
I have one of those lights similar to the LV light. I don’t recommend it It works great but I frequently forget to turn it off and come back in the morning to find the batteries nearly worn down which gets expensive unless you use rechargeable batteries. I would rather have a corded light. -- Nathan, TX -- Hire the lazy man. He may not do as much work but that's because he will find a better way. |
#8 posted 01-26-2021 06:05 PM |
LOL – lots of difference between a Mag-lite flashlight and one of those circular magnifying work lamps! For the later through, you can get them all over the place – Amazon, Home Depot, WalMart, etc… they are everywhere. Just a note: I have one of the magnifying ones on my Hegner, and I have just a plain articulated arm light on my Delta. I rarely, if ever, use the magnifying part of the lamp – and pretty much just use it as a light source; same as the non magnifying one on my Delta. YMMV. Cheers, -- Brad in FL - In Dog I trust... everything else is questionable |
#9 posted 01-26-2021 06:56 PM |
Assuming that the OP wants a magnetic mount work light, do a search for “Sewing machine light”. I got 2 led lights on Amazon for $17, with magnetic (with adhesive discs included, if desired) base, flexible gooseneck, and bright leds. One is on my scroll saw, the other on my band saw. Both work great. They are not battery powered- need to plug in. |
#10 posted 01-29-2021 09:07 PM |
Grizzly has several styles: T26544 – LED Light with 40 lb. Mag Base and Flexible Arm -- The hump with the stump and the pump! |
Forum | Topics |
Woodworking Skill Share
13201 |
Woodturning
2814 |
Woodcarving
569 |
Scrollsawing
416 |
Joinery
1893 |
Finishing
6347 |
7909 |
32769 |
CNC Woodworking
330 |
Hand Tools
6453 |
Jigs & Fixtures
1804 |
Wood & Lumber
7277 |
1633 |
Focus on the Workspace
2635 |
1272 |
Woodworking Trade & Swap
5418 |
LumberJocks.com Site Feedback
2396 |
Coffee Lounge
9660 |
