01-26-2021 12:15 PM
Topic tags/keywords:
bandsaw
grizzly
jet
Hey gang,
I’m upgrading my band saw game and have a couple of used options available at a decent price. I would be most appreciative of any feedback on what might be the better buy. The 14” jet weighs about half as much but has a few newer features, is near new and is 12” vertical clearance. The grizzly is older, but some of the older stuff is better, it has an additional speed, an additional .5 HP and the heavyweight will keep it solid. I will lose about 4” of cutting height but my jointer is 8” so I may not be losing that much by not being able to matchbook a 12” board.
The first is Grizzly G1073 16” Bandsaw at $600 It is a 95 – 96 model I believe but is in good shape with new bands and the fence. Missing the sled, but that’s not a big deal for me.
Specs One-piece cast iron body Balanced cast iron wheels with rubber tires Hinged wheel covers Micro-adjustable blade guides (upper & lower) Heavy-duty stand to prevent vibration 2 H.P., 110V / 220V motor prewired for 220V Wheel brush removes sawdust from wheel Dust collection port fits most home shop vacuums Fully adjustable upper wheel Heavy-duty rip fence Cast iron table 3 blade speeds Easy blade changes Specifications: Maximum cutting width: 16-1/2” Maximum cutting height: 7-3/4” Table tilt: 45° right, 10° left Table size: 17” x 17” Blade length: 113” Blade width: 1/4” to 1” 3 blade speeds: 2275, 2720, 3265 F.P.M. Upper and lower ball bearing blade support Overall height: 72” All ball-bearing construction Comes with one 1/2” blade Working weight: 408 lbs. Motor type: 2 H.P.
The next is a 2019 or 2020 Jet jwbs-14dxpro Bandsaw for $700 “the pro model” the lesser model has way less clearance vertically.
Specs Built-in 12” resaw capacity for cutting larger pieces of wood 2 Speed poly-v belt drive system Newly designed upper and lower cast iron frame for increased strength and rigidity Easy to view blade tracking window Blade guide post with rack and pinion adjustment Upper and lower ball bearing guides reduce friction for longer blade life Quick release blade tension for convenience New enclosed stand with storage shelf and easy access door Built-in retractable blade guard moves up and down from 0-12” resaw New high tension spring design allows for greater blade tensioning Length: 29” Part Number: 710116K Jet Bandsaw Cutting Capacity Width: 13-1/2” Jet Bandsaw Cutting Capacity Height: 12” Minimum Saw Blade Width: 1/8” Maximum Saw Blade Width: 3/4” Blade Speed: 1500/3000 SFPM Blade Length: 105” Table Dimension (LxW): 15” X 15” Table Tilt: 10° left, 45° right Table Height From Floor: 43-1/2” Dust Port Outer Diameter: 4” Dust Collection Minimum CFM: 300 cu.ft/min Stand Type: Closed Wheel Diameter: 14” Jet Bandsaw Motor: 1-1/4 HP, 1 Ph, 115/230 V Prewired Voltage: 115 V Height: 77” Width: 28” Length: 29” Net Weight: 247 lbs Shipping weight 260 lb.
#1 posted 01-26-2021 02:14 PM
Cast iron wheels are better than aluminum, so is a bigger table.
But for some people, resaw depth is the most important factor.
#2 posted 01-26-2021 08:42 PM
I have the 16” old Grizzly I’ve had it for about 20 years, it’s a great saw. A little low on resawing capacity but a nice heavy and solid machine. I also have an 18” Ricon with a 12” resaw capacity
-- Ken
#3 posted 01-26-2021 09:08 PM
Based on what you have said about your needs. Does not sound like you need a tall resaw ability. I would go with the grizzly. You mention it has the fence, but missing the sled. What is a sled?
To start, I have some experience with the Jet saw. A bit older, but same design, and motor HP. At 1.25hp. That saw is under powered for its rated resaw capacity. But I feel it was ok with thinner stock. The Grizzly won’t do tall resaw, but the 2hp motor will handle anything you throw at it all the way up to its max 7.75’ clearance. I base that off my grizzly GO513×2. it has a 2hp motor as well, and has no issue with thick stock. So I feel, just my .2 cents. If you don’t need the tall clearance the Grizzly is just more saw. and its a rock. So I went a read what I could find on it. Old article on fine wood working sort of stuff. and it seemed to have favorable reviews. One comment about not bothering with a blade above 3/4” wide. Other reading, and more info was on what this used Grizzly has sold for in the past. Seems $600 is a little high. Seems the high number I see and most recent was in 2016, on this linked auction site at $467. https://zettauction.hibid.com/lot/19737-80600-263878/grizzly-g1073-16--bandsaw-on-rolling-stand-w-extra/ And it was an open stand model. Not sure about open or closed base on the others. But older post, like 2006 old. But guys were asking the same questions as you. Is it worth buying? And they were looking at $300/$400 asking prices. So is it worth $600 in 2021? Maybe a negotiating tool with past prices being lower?
Not sure if you have seen this yet, but Grizzly still has the manual on the site. https://cdn0.grizzly.com/manuals/g1073z_m.pdf
https://www.lumberjocks.com/topics/50842 https://www.proxibid.com/Industrial-Machinery-Equipment/Manufacturing/2003-GRIZZLY-MODEL-G1073Z-16-Z-SERIES-BAND-SAW-S-N-046543-2-PHOTOS/lotInformation/57206454
Good luck.
-- John
#4 posted 01-26-2021 09:36 PM
The bigger and heavier the better. Next is the ease of guide adjustment is what matters. I looked at Griz, Jet, Laguna, Rikon and Harvey. I bought a Harvey C14 ( 14 inch, 3 HP) I was NOT impressed with Jet.
For many big old heavy machines, you can buy Carter guides. So big iron, heavy iron wheels, and retrofit guides. I am coming to the viewpoint that we should buy woodworking machines by weight. I would not even dream of aluminum wheels.
Forum |
Topics |
Woodworking Skill Share
Your woodworking skills are displayed for several lifetimes in each project. Have you had to compromise your project...
13194 |
Woodturning
On the lathe, by the lathe: do you have questions? frustrations? tips? This forum is for all the woodturners out there.
2810 |
Woodcarving
Relief, 3D, chip-carving, whittling; carving knives, chisels, pocket-knives, power tools. If you are a carver or want...
568 |
Scrollsawing
Intarsia, fretwork, intricate design cutting and more! This forum is for scrollsawers: share your tips, ask questions...
416 |
Joinery
Have a question? a tip/strategy to share? a challenge, perhaps? Share your "joinery" discussion here.
1891 |
Finishing
The finish, whether paint, wax, stain, or something else, can make or break a project. What are your tips and questio...
6338 |
Looking for information on designing your projects? Having difficulties reading project plans? Looking for help with ...
7900 |
Are you unsure of which tools, or hardware, you need, or which brands to buy? Investing in tools and hardware can be ...
32729 |
CNC Woodworking
Questions and answers about CNC machines, tooling, best practices, and projects.
329 |
Hand Tools
Wood, your hand tools, you and a little know-how. Share your questions, tips and strategies for the use and maintenan...
6449 |
Jigs & Fixtures
Using a jig is like having a couple extra hands helping out. Show us your jigs, share your tips, strategies and, of c...
1803 |
Wood & Lumber
Different wood requires different woodworking strategies - from cutting to finishing. Share your tips and challenges ...
7275 |
Before you pick up those woodworking tools, take the time to ensure your safety in the shop! Eyes, ears, fingers, and...
1629 |
Focus on the Workspace
Are you looking for or do you have tips to share regarding the workshop? Storage, equipment placement, efficiency, an...
2630 |
If you are selling your work, then you have entered a woodworking dimension with added complexity and stress. If you...
1272 |
Woodworking Trade & Swap
All of us are holding onto treasure in our shops, that we either don't need, don't want, or could part with if presen...
5412 |
LumberJocks.com Site Feedback
Connect with the Website Gurus and tell us what you are thinking, suggestions, problems, functionality issues, and so...
2396 |
Coffee Lounge
Need a break from all the standing and wood dust? Chat with your Forum Friends about their projects, their life, thei...
9651 |
