Forum topic by newwoodbutcher | posted 01-25-2021 07:00 PM | 571 views | 0 times favorited | 16 replies | ![]() |
I’m building this desk -- Ken |
16 replies so far
#1 posted 01-25-2021 07:20 PM |
What is your area of concern? It looks like the photo of that desk there has everything as being draw-bored or at least pegged tenons, I don’t think I’d be to worried about them pulling apart if that’s the case. I also wouldn’t be too concerned about 3/4” tenons either, but 7/8” and you’d just be making through mortises in the legs, which I probably wouldn’t do. Are there cross braces from front to back for the four legs in the middle of the desk? That may have been another consideration with the plans being at 1/2” deep. Truthfully, with modern glues and tight joinery, I don’t think I’d be that concerned about the 1/2” tenons if they’re pegged/draw-bored together, unless you foresee a lot of racking stress on the desk in its future. But, I’ve not built a desk like that, so I’ve not had first hand experience (the proverbial “grain of salt” disclosure) -- Mos - Twin Cities, MN - http://www.youtube.com/MosquitoMods - http://www.TheModsquito.com |
#2 posted 01-25-2021 07:52 PM |
You can get by with 3/8” tenons just as well as they’ll still be plenty strong. If you are adventurous you can offset them to the outside a bit to gain room for more length. For the intersection inside a mortise, a common approach is to bevel the ends of the tenons to 45 degrees. They then fit together like a mitered corner and have the full length glue surface on the outside face. (leave a slight gap at the ends where they meet inside the mortise). |
#3 posted 01-25-2021 07:58 PM |
Mosquito, -- Ken |
#4 posted 01-26-2021 08:29 PM |
Ok I guess I’m once again over building. Thank you for responding -- Ken |
#5 posted 01-26-2021 08:47 PM |
This looks like the Aurora table desk that Darrell Peart has in his G&G books. I’d trust his construction methods every time. -- Earl "I'm a pessamist - generally that increases the chance that things will turn out better than expected" |
#6 posted 01-27-2021 03:05 AM |
Thank you Earl, personal experience? -- Ken |
#7 posted 01-27-2021 03:37 PM |
I think that I would make sure that the aprons are not quarter sawn. Pegs so close to the end could tend to pull out with QS boards. You want the pegs to go into flat sawn grain to make them a little stronger. -- Nathan, TX -- Hire the lazy man. He may not do as much work but that's because he will find a better way. |
#8 posted 01-27-2021 05:08 PM |
I think you are all set with advice, so I will give some more :) You might just try your 1/2” tenon in scrap, glue up a T, let is sit for a day, then try your hardest to break it apart – you probably won’t even able to get it to budge til you hold it at an angle and stand on it. But you will know firsthand that your one joint is tough; three per side will be bulletproof. -- Mike (near Boston) ... Laziness is the mother of invention, necessity is the mother of exhaustion - me |
#9 posted 01-27-2021 07:25 PM |
Double tusk tenons are the traditional way to join thin aprons or dividers to a leg. I’m kind of with Mosquito, I think you’ll be fine since there are 8 legs in this thing. -- Everything is a prototype thats why its one of a kind!! |
#10 posted 01-27-2021 08:09 PM |
Once again, Lumberjacks members are helpful, thoughtful and responsive. Thanks for all your responses. Here is where I’ve landed. I’m thinking once again that my tendency to over build for strength has become counter productive. -- Ken |
#11 posted 01-27-2021 11:15 PM |
Thanks Robert, -- Ken |
#12 posted 01-28-2021 03:16 AM |
Ken – Darrell Peart is probably the top G&G furniture maker in the country. He also occasionally posts on LJ and teaches a fair bit too, though I have not been fortunate enough to attend one of his classes. I think he has 3 books out. If I recall, this was in one of them. He also goes into the G&G history quite a bit too. All in all, they are interesting to read. There are numerous LJ’s that have built his designs from the books so you should be able to get plenty of commentary from them. -- Earl "I'm a pessamist - generally that increases the chance that things will turn out better than expected" |
#13 posted 01-28-2021 03:54 AM |
Thank you Earl, -- Ken |
#14 posted 01-28-2021 06:54 AM |
Lazyman, been thinking about your point. None of the aprons are quarter sawn but since my pin of choice is about 1/4” diameter I’m thinking draw boring might be too much for such a short tenon. My test joint came out good and strong with two bamboo pins drilled and hammered home without the added stress of draw boring. I haven’t really stressed the test joint yet, waiting over night for a good dry glue up. But my feeling about that joint is that it will be plenty strong for many years. So I went ahead and cut all the apron and stretcher cheek and cheek shoulders 1/2” deep and 1/2” thick. I’m cutting the mortises in the legs and finishing the tenons tomorrow. Thank you all again -- Ken |
#15 posted 01-28-2021 03:54 PM |
I agree. I actually meant to but forgot to add that I would not draw bore these dowels since they are so close to the edge and ends, even without the concern of quarter sawn grain . -- Nathan, TX -- Hire the lazy man. He may not do as much work but that's because he will find a better way. |
Forum | Topics |
Woodworking Skill Share
13199 |
Woodturning
2814 |
Woodcarving
569 |
Scrollsawing
416 |
Joinery
1893 |
Finishing
6345 |
7906 |
32761 |
CNC Woodworking
330 |
Hand Tools
6453 |
Jigs & Fixtures
1804 |
Wood & Lumber
7276 |
1633 |
Focus on the Workspace
2632 |
1272 |
Woodworking Trade & Swap
5417 |
LumberJocks.com Site Feedback
2396 |
Coffee Lounge
9658 |
