Routing a flush-fit cover for an existing opening.
Forum topic by Adam posted 01-25-2021 01:37 PM 327 views 0 times favorited 2 replies Add to Favorites Watch
View Adam's profile
Adam
42 posts in 3569 days
01-25-2021 01:37 PM
Hey all. I have a need to replace a missing ice box lid, but I can’t figure out how to pattern it. The lid needs to fit flush inside the existing opening, which is in an existing countertop. I figured to make a pattern and then use a flush-trim bit, but I can’t figure out how to make the pattern, as using the opening will just give me another opening. Thoughts?
2 replies so far
View Walker's profile
Walker
470 posts in 1812 days
#1 posted 01-25-2021 06:38 PM
Pictures would help.
You could use cardboard, styrofoam, piece of paper etc to mock up the lid, then transfer that to a pattern. Or use a cheap piece of particle board, cut it larger than the opening, then sneak up on the cuts until it is a perfect fit and use that as your pattern. Or do the same thing with the actual workpiece if you’re brave.
-- ~Walker
View CaptainKlutz's profile
CaptainKlutz
5167 posts in 2834 days
#2 posted 01-25-2021 07:30 PM
+1 pictures?
Offsetting cut from template is easy.
Use a 3/4” template guide on router with 1/2” spiral bit, instead of flush trim. The final cut will be 1/8” larger/smaller than template OD (depending on outside/inside cut of template). HF sells a cheapo template guide set for $16.
Can use smaller or larger guide for different cut offsets.
Best Luck.
-- If it wasn't for bad luck, I wouldn't have no luck at all, Doom, despair, agony on me… - Albert King - Born Under a Bad Sign released 1967
