Forum topic by Superman32 | posted 01-25-2021 01:33 PM | 263 views | 0 times favorited | 7 replies | ![]() |
Topic tags/keywords: dust collection Can someone help me? |
7 replies so far
#1 posted 01-25-2021 02:02 PM |
Not enough to notice. I’m sure that joint causes some turbulence and drag, but it would take laboratory quality instruments to measure it. Over time there will be a small build up of fine dust in there, but that’s also nothing to worry about. -- Our village hasn't lost it's idiot, he was elected to congress. |
#2 posted 01-25-2021 02:08 PM |
That is how pvc goes together. The female side has a slight taper so the male side will not bottom out and make a smooth joint. As Fred said, it probably won’t cause any problems. |
#3 posted 01-25-2021 02:23 PM |
If possible, you can use a sweep in lieu of 45s, that will help with smoother flow/less resistance. Just a thought…..... -- Don't let perfection get in the way of plenty good enough |
#4 posted 01-25-2021 03:16 PM |
Or go with steel duct with long radius 90’s. And the plus is no shocks off of steel. And about the same price as pvc. |
#5 posted 01-25-2021 08:54 PM |
4” won’t cut it for most things. Sorry. Have you read all of Bill Pentz papers on the subject? I use 4 inch only for the drop to my spindle and disk sander. I will probably drop a 4 inch to a blade guard on my TS, but even the drop to my TS and BS will be 6 inch. BS splits the 6 to two 4’s right at the ports. 6 inch right into the TS base. 4 inch port to connect my jointer and planer, as they are only chip collection, no dust to speak of. Same port will feed a 4 to twin 2 1/2 for the top and bottom of the router though I suspect it will be inadequate. Log sweep metal are really expensive. I am using two adjustable 45’s to make a longer radius. PVC will not meet code in a lot of places. You can run a bare wire through it, or some run a screw in every couple of feet all wired to ground. 6 inch spiral duct is really expensive, but so are my lungs. You can get a little aerometer to measure velocity pretty cheap. I was quite surprised. Not only did it prove to me 6 inch is required, but I will probably upgrade to a 3 HP system. Then the trunk from DC to the miter hood and split to the overhead 6 inch will move up to 8 inch. |
#6 posted 01-25-2021 11:39 PM |
I agree with all of this! -- Everything is a prototype thats why its one of a kind!! |
#7 posted 01-25-2021 11:41 PM |
ive got a double 45 situation in several places in my shop.it’s no issue.im using 4” throughout my shop from a 2hp jet dc with no problem. -- working with my hands is a joy,it gives me a sense of fulfillment,somthing so many seek and so few find.-SAM MALOOF. |
Forum | Topics |
Woodworking Skill Share
13199 |
Woodturning
2814 |
Woodcarving
569 |
Scrollsawing
416 |
Joinery
1893 |
Finishing
6345 |
7906 |
32761 |
CNC Woodworking
330 |
Hand Tools
6453 |
Jigs & Fixtures
1804 |
Wood & Lumber
7276 |
1633 |
Focus on the Workspace
2632 |
1272 |
Woodworking Trade & Swap
5417 |
LumberJocks.com Site Feedback
2396 |
Coffee Lounge
9658 |
