Forum topic by spindeepster | posted 01-25-2021 12:43 AM | 499 views | 0 times favorited | 9 replies | ![]() |
I’d like to replace my 1/4’drive Craftsman router mounted on this router table with an upgraded router with a 1/2” drive. Will this Craftsman Table Saw Router Wing accommodate routers from other manufacturers? Thanks!! |
9 replies so far
#1 posted 01-25-2021 01:34 AM |
For certain it depends. |
#2 posted 01-25-2021 04:56 AM |
I would imagine that just about any router would fit. Most Routers have both 1/4” and 1/2” collets. -- John |
#3 posted 01-25-2021 07:59 AM |
if “upgrading” is going to a 1/2” collet, is a 1/2” collet available for the router you have? and yes- it is certainly a possibility. :) |
#4 posted 01-25-2021 09:13 AM |
for certain? In French we say “les conseilleurs ne sont pas les payeurs” -- Sylvain, Brussels, Belgium, Europe - The more I learn, the more there is to learn |
#5 posted 01-25-2021 10:24 AM |
Anything is possible with a big enough hammer. Pretty much guaranteed you will need to drill new holes. For a smooth top, you can fill the old holes with JB-Weld and sand smooth. Does your table have inserts for the router hole? While you are at it, make yourself some zero clearance blade inserts with a riving knife. ( or micro-jigs) By far the biggest safety improvement for an older saw like yours. |
#6 posted 01-25-2021 12:22 PM |
Thanks for the replies. tvrgeek, the blade inserts are not necessary as this saw is exclusive to dado blades only. My primary table saw has inserts, thanks. I intend on taking the wing off this afternoon and taking a long look at the underside. I’m going to figure out if it is compatible to other routers. I do not know if a 1/2” collet is available for the inexpensive Craftsman router that is mounted on it now. |
#7 posted 01-25-2021 12:37 PM |
You’ll know for certain when you do that! -- Everything is a prototype thats why its one of a kind!! |
#8 posted 01-25-2021 12:44 PM |
Ah, a luxury! Bigger collets let you spin bigger bits, but they need more power. My old Craftsman router collet is not replaceable anyway. The one feature I like is the spindle lock is the power switch, so easier to reach when I had it mounted n a DIY table. My Tridon is a little clumsy to reach, though I am going to extend the rod to make it easier. Snap a picture of the underside with a ruler in the frame. Taking the wing off is a lot of work. ( Just put one on my Ridgid) |
#9 posted 01-25-2021 12:57 PM |
“Bigger collets let you spin bigger bits, but they need more power.”.... Yep! And that is the motivation to upgrade the router. You are right about removing the wing, I have relocated it 3 times now. First, I attached it to the wrong side of my table saw, and remounted it on the other side. Next, I got this saw to use exclusively with my dado blades, and moved the router again! It is a lot of things, but light s not one of them!! |
Forum | Topics |
Woodworking Skill Share
13194 |
Woodturning
2812 |
Woodcarving
569 |
Scrollsawing
416 |
Joinery
1892 |
Finishing
6339 |
7903 |
32746 |
CNC Woodworking
329 |
Hand Tools
6450 |
Jigs & Fixtures
1804 |
Wood & Lumber
7275 |
1632 |
Focus on the Workspace
2630 |
1272 |
Woodworking Trade & Swap
5412 |
LumberJocks.com Site Feedback
2396 |
Coffee Lounge
9656 |
