Forum topic by nate22 | posted 01-23-2021 11:28 AM | 690 views | 1 time favorited | 26 replies | ![]() |
I am wondering what the best finish is for wood projects. I see a lot of people using beeswax or some kind of an oil to finish projects with. Are those good ones to use or is there other ones that are better. What I am making is cutting boards, coaster’s, and jewelry holders. Only thing I have used in the past was polyurethane for the furniture I make. Just wondering what the best finish would be. -- Gracie's wooden signs. Middlebury, In. |
26 replies so far
#1 posted 01-23-2021 11:58 AM |
For finishing small projects and even furniture, I’m in the oil finish camp. I use Minwax Antique Oil as my base with thinned coats sanded in with wet-dry automotive finishing paper in 600 or finer grit. Multiple applications over several days until I get the level of luster and grain filling desired. I wait 24 hours between each application. For food items such as cutting boards I use one of the salad bowl oils such as Watco Butcher Block Oil. On turned items, I use wax free shellac as a base before applying oil. -- "Good enough" is just another way of saying "it could be better"... |
#2 posted 01-23-2021 12:00 PM |
There is no such thing as “best finish for wood projects”. There is, however, best choices for certain types of projects….though everyone has a different slant on what they are. For the stuff you names I would use mineral oil on the cutting boards (along with a statament on how to care for and renew the finish), probably a varnish on the coasters (call it “ploy” if you want) and probably shellac or nitro lacquer on the jewelry holders. I might also consider a waterborne on the latter. But this is just one of the many opinions on what to use. -- Our village hasn't lost it's idiot, he was elected to congress. |
#3 posted 01-23-2021 03:20 PM |
Well, my go to finish for “most” things is GF Arm-r-seal. But i wouldn’t use it on cutting boards, for things that actually get cut on i just use pure tung oil. If i want a more traditional looking finish I use various methods, one of them being what Kytoolsmith wrote. |
#4 posted 01-23-2021 04:52 PM |
I agree with Fred on all these. Boxes need something that doesn’t smell or have a long dry time before all the solvents evaporate, A closed box (and drawers) hold these odors for a very long time. Shellac gives a fine looking surface and pops the grain. The overwhelming favorite for boards is some mineral oil (maybe blended with bees wax, heated up and applied), or one of the other non-rancid turning nut oils. No film finish as this will quickly turn into a big mess. For coasters, the cutting board formulas are good (with the maintenance), but a film finish is great protection, but if any moisture gets through it will start to peel. Also consider ways to pre-finish the insides of boxes. It is much easier to get an even finish if you need to rub out or sand the finish and not have to worry about getting into the interior corners. |
#5 posted 01-23-2021 05:29 PM |
for cutting boards mineral oil,for everything else i use the maloof oil blend,or general finishes oil based finishes such as arm r seal.experiment until you find the one that you like,there is no perfect finish. -- working with my hands is a joy,it gives me a sense of fulfillment,somthing so many seek and so few find.-SAM MALOOF. |
#6 posted 01-23-2021 05:35 PM |
General finishes wood bowl finish for cutting boards as recommended by Charles Neil. He also recommended shellac over danish oil before any sort of varnish. I’m a fan of gloss poly on small projects. Sprayed WB poly on larger projects. |
#7 posted 01-23-2021 06:32 PM |
As you can see everyone has a different idea on how to finish things. A couple here that I disagree with. First shellac under oil. The shellac will prevent the oil from penetrating. Second mineral oil is fine but it never dries or “cures”. When wax is added it helps. My preference is processed or heat treated walnut oil for cutting boards and food utensils; also works on other small wood working items and can be top coated with a hard finish. It penetrates and cures to a dry state, can be re-applied as needed and a wax top coat can be added. WoodCraft has a walnut oil and wax paste that makes a good top coat. Processed walnut oil does NOT become rancid as one person suggested and is non allergenic due to the heat treatment. Mahoney’s is a good brand. For items like jewelry boxes shellac is good, quick, and easy. It comes clear or amber and other colors can be added. Most other finishes can take months to to fully cure and lose the odor that can be trap inside a box or cupboard. I have put poly on clock cases that have given off an odor for over a year every time I open the case to wind the clock. -- Les B, Oregon |
#8 posted 01-23-2021 06:51 PM |
LesB, I use shellac under oil on turned items for exactly the reason you give… It seals the wood when finishing on the lathe. That way I’m not using as much “oil” to create the top coat finish and I have lower curing time during on-lathe finishing. I’ve done this with both Minwax Antique Oil and Watco Danish Oil with good results. I didn’t invent the method… Read it in one of my books on turning. -- "Good enough" is just another way of saying "it could be better"... |
#9 posted 01-23-2021 07:24 PM |
I am not being sarcastic but I honestly don’t think there is any one real answer to this question. Do you want shiny or satin or flat or the bare wood look? What species of wood is being finished? Do you want to spray it, brush it, wipe it? Finishes are like a certain body part. Everybody’s got one, but the upside of that is that the possibilities are endless. -- Andy - Seattle USA |
#10 posted 01-23-2021 07:36 PM |
You really need to look up finishes and there applications. Each project may have a different need.. I may use a pre-cat on top, but polyurethane on the top to repair future scratches. It just varies. Sherwin and Williams calls th eir conversion varnish the Cadillac of finishes.. |
#11 posted 01-23-2021 11:31 PM |
Couple of excellent resources…. Charles Neil -- Andy - Seattle USA |
#12 posted 01-23-2021 11:47 PM |
ive heard you talk about walnut oil many times,i think i need too give it a try les. -- working with my hands is a joy,it gives me a sense of fulfillment,somthing so many seek and so few find.-SAM MALOOF. |
#13 posted 01-24-2021 12:18 AM |
And let’s not forget about my latest arrow in the quiver…Rubio Monocoat and the other wax finishes. -- Andy - Seattle USA |
#14 posted 01-24-2021 12:51 AM |
got a sample yesterday andy gonna try it out tomorrow,ill let ya now my thoughts on your review thread. -- working with my hands is a joy,it gives me a sense of fulfillment,somthing so many seek and so few find.-SAM MALOOF. |
#15 posted 01-24-2021 12:55 AM |
It depends on the end use of the product. There is no ONE good finish for everything. For cutting boards you need food safe finishes and there are lots of them. for outdoors you might want a UV resistant finish. For tables where you will have alcoholic drinks, you might want a lacquer. For chairs with high use and handling, you might want a polyurethane or lacquer. For most everything that will have a lacquer or poly finish, it is a good idea to use shellac for a first coat ( sealer). It is a “primer” for any finish too..even paint. If I use an oil, though, I like to put it on bare wood..maybe 2 coats. Good luck, Nate….............Cheers, Jim -- Jim Jakosh.....Practical Wood Products...........Learn something new every day!! Variety is the Spice of Life!! |
Forum | Topics |
Woodworking Skill Share
13194 |
Woodturning
2812 |
Woodcarving
569 |
Scrollsawing
416 |
Joinery
1892 |
Finishing
6339 |
7903 |
32747 |
CNC Woodworking
329 |
Hand Tools
6450 |
Jigs & Fixtures
1804 |
Wood & Lumber
7275 |
1632 |
Focus on the Workspace
2630 |
1272 |
Woodworking Trade & Swap
5412 |
LumberJocks.com Site Feedback
2396 |
Coffee Lounge
9656 |
