OK, Thought I would be smart and "upgraded" to a compound miter saw. Big mistake. Flexible, inaccurate, confusing and curved cuts no mater how much good advice I got from this forum.
What I really needed was a jig. I looked at all the "reviews" out there and they look to be cut-and-paste from someone who read the package. Nothing from anyone who actually used one on typical crooked walls.
Any advice? Kreg, Milescraft and Bench Dog seem to be the ones always in the no-review-review advertisements.
Or is the right way just to clamp a lip across my saw to hold it at the install angle?
I spent darn near a day filing and shimming my Ridgid to be closer to accurate, at least crosscut. It's miter adjustments are crude, so I may try to design a threaded micro adjuster. I regret selling my old non-compound old Delta. I wish reviews of saws were more than feature summaries focused on job-site carpentry. Yea, I know, that is their design market.
The bed of the miter saw is always the ceiling (if you didn't already know this but other may not). The clamp a lip should work well and would mimic the work holder the is usually missing on the old hand saw miter boxes. Kreg makes a saw jig here It seems like I have also seen a jig to make sure you have the molding bedded at the proper angle when nailing in place.
Watched several videos. Of course, all are perfect and easy, magically solving everything.
Making a jig to hold in place for nailing would be a big help. Next time for sure. For some reason, me and trim never seem to get along. My last project, trim from the same HD, not all the profiles were exactly the same board to board.
My last house was easier, as it was a Levitt so had virtually no trim. I prefer the Craftsman style, so much of the trim I put in was square. My current house is "nuvo eclectic" so it has a mix of Colonial, Victorian, and modern trim. I am sort of tempted to rip it all out and do it my way. Stupid popcorn ceilings. But gad, the cost would add up.
I have. Dewalt supplied "lips", but I find it easier/more accurate, to hot glue a piece of stock across the bed of the miter saw (do not glue to the swiveling part of the table). As posted, remember the bed is the ceiling!
Walls, ceilings, and corners are never true.
It doesn't matter what kind of jig or saw you use.
The only answer is test fitting each corner as you go,
unless you're using paintgrade and just plan on caulking open gaps.
I have the Kreg jig. It came with the spring angle gauge. If you follow all directions it works really well. But as mentioned most houses the walls and ceilings are never square so sometimes you get conditions where your cut is perfect, but it just won't fit into the space right, the wall and or ceiling twist and bend the wood etc.
ControlFreak. Thanks for that tip about the bed being the ceiling. I've always had trouble with crown moldings. I've struggled and got them right somehow.
I always flat cut crown and use a little math to figure out the angles. I briefly had a SCMS but my non-sliding 10" Ridgid was pretty accurate out of the box, FWIW I use a CMT blade. I always cut a little long too as the tape measure blade is always straighter than the curvy wall. I always cope too as it just fits much better.
I looked up the Kreg jig on Amazon and it has over 1000 reviews. It's hard to believe none of them would be informative as to its real world functionality.
Aside from reducing the size of molding one can cut I imagine it works well to hold the molding at the proper spring angle (which is often not 45 degrees).
Ridgid 10 inch compound miter. Fixed pivot
Bed was not flat. Neither fence was 90 degrees to the table and of course I had to adjust them to 90 against the blade, but that was an adjustment. However, the 45 and crown indents are not perfect and if you want to cut 45.2, it is more than a bit clumsy. No matter what I tried, cutting crown with the trim flat and compound angle, the cut was slightly curved. Freud 80 tooth blade, though it is a thin kerf. So I tried my a full kerf, came with one of my saws blade just to see, and it was sill just slightly curved. Cut real slow. I was holding off getting a low hook full kerf ( I think Amana is the best overall) to see if I was going to get a slider as they really should run a negative hook.
I would like a deeper crosscut and was thinking about a slider, but more to flex. Makes me wonder, should we buy a miter saw for woodworking by weight?
So, my conclusion is not to do compound. I guess just glue a stop on a bit of MDF that I can tape down is about as accurate a jig as I can get. Then I only need to make the 45 micro adjustable.
I have coped a lot of baseboard, but not crown. OK for inside, but outside has to be mitered.
So as not to confuse me on which cut, I keep a set of inside and outside corners hanging on the wall so I can verify I set it correctly.
I do like the LED light that gives a shadow on both sides of the blade. Quite accurate actually.
I looked up the Kreg jig on Amazon and it has over 1000 reviews. It s hard to believe none of them would be informative as to its real world functionality.
It doesn't really change how big you can cut. It can hang over a bit. I can't really afford crown molding any bigger than it can cut.
But yes,the key for me is that it holds it at the right spring angle. There is a setting underneath, so you set it for example for 52/38. I have the molding holders for my DeWalt saw but there is too much room for error there trying to set it to the correct spring angle and getting it to stay.
Related Threads
LumberJocks Woodworking Forum
2.5M posts
96K members
Since 2006
