Forum topic by Karda | posted 01-23-2021 04:44 AM | 601 views | 0 times favorited | 26 replies | ![]() |
Hi, I want to build a chisel rack but am design challenged, I don’t have a picture of what I want, I saw it in a Rob Cossman video. In the back tool rack he has his chisel in a rack handle down. I couldn’t see detail or for a very long period. I would like to build a rack that does that but don’t know where to start. This is where I will out the chisels it is between shelves and the rack should slant thanks Mike |
26 replies so far
#1 posted 01-23-2021 05:16 AM |
Quickest way is go to Harbor Freight and get one of those magnetic tool bars for $3 or whatever. Boom, done. |
#2 posted 01-23-2021 05:25 AM |
no you dont need hf,just make a simple rack like i did. -- working with my hands is a joy,it gives me a sense of fulfillment,somthing so many seek and so few find.-SAM MALOOF. |
#3 posted 01-23-2021 05:34 AM |
no magnet bar I want wood not metal I’m a wood kinda guy. I can’t have a face mounting rack because I don’t have a face to mount it on |
#4 posted 01-23-2021 06:07 AM |
All I did was, take a 3/4” board, or piece of plywood, and cut it to about 3” and as long as I needed for a given group of chisels or carving knives. Then I drilled holes big enough to allow the shaft to fit through. Last, I cut into the holes so the chisels could slip in and rest in the hole. It’s late or I’d shoot a photo. |
#5 posted 01-23-2021 06:34 AM |
The rack in the wall cabinet, well one of them. -- Lifting one end of the plank. |
#6 posted 01-23-2021 07:25 AM |
Andre’s photo is, exactly, what I attempted to describe. |
#7 posted 01-23-2021 07:56 AM |
thanks for the pic Andre that will work even better than what planed |
#8 posted 01-23-2021 12:35 PM |
@Karda I think this is what you are looking for. I also have one that is a bit rougher in my projects. The magnetic holder is awful as I kept knocking them off it. I also like to see the blades when selecting what I want. |
#9 posted 01-23-2021 03:11 PM |
Well, the OP originally wanted the chisels facing up, in which Rob Cosman uses magnets inset into wood, but whatever. Yeah the down facing is the more traditional |
#10 posted 01-23-2021 06:52 PM |
SMP I want what works, I could also use a block like a knife block and slant it out. you he used magnets that what I want to know I could not see it clearly that why I asked of those who new more and were more experienced. How many times during a project do you change your mind. Its simple My option was not the best. Live with it I am |
#11 posted 01-23-2021 07:41 PM |
I keep mine in a tray each chisel separated with a piece of lexan. Have a strip with half round cutouts sized and positioned at the ferrule that limits forward movement to protect the tips. A sliding lexan lid covers all. Makes a good carry case as well as bench storage. Use 1/4” stock and 3/32” lexan. Needs a thin kerf blade for the lexan dados to prevent rattles. -- The hump with the stump and the pump! |
#12 posted 01-23-2021 10:02 PM |
Doesn’t need to be complicated, this is knocked together out of scrap contruction lumber. But essentially the same as Andre’s and Pottz’s, just a set of holes to fit the tools in. Holes drilled with a stepped bit, channels cut to slide the tool in from the side. -- Be yourself; everyone else is already taken. |
#13 posted 01-23-2021 10:15 PM |
Sorry, just re-read the request, As near as I can tell Rob Cosman’s is essentially a shelf with a magnetic tool bar (well, a wooden batten with magnets inserted) above to hold the chisel in place. Doesn’t need to be slanted, rare earth magnets will hold the chisel straight up with no problems. -- Be yourself; everyone else is already taken. |
#14 posted 01-23-2021 10:33 PM |
thanks for the picture they are a great help. i have a hard time imagining something as I want it but if I have a picture then I can do something. I feel stupid having to ask but sometimes my mind just won’t go there |
#15 posted 01-23-2021 11:08 PM |
I Googled Rob Crossman chisel rack and got this image. -- John |
Forum | Topics |
Woodworking Skill Share
13194 |
Woodturning
2812 |
Woodcarving
569 |
Scrollsawing
416 |
Joinery
1892 |
Finishing
6339 |
7903 |
32747 |
CNC Woodworking
329 |
Hand Tools
6450 |
Jigs & Fixtures
1804 |
Wood & Lumber
7275 |
1632 |
Focus on the Workspace
2630 |
1272 |
Woodworking Trade & Swap
5412 |
LumberJocks.com Site Feedback
2396 |
Coffee Lounge
9656 |
