Forum topic by Travis | posted 01-22-2021 09:24 PM | 430 views | 0 times favorited | 10 replies | ![]() |
I am building my first chest of drawers and I recently added the drawer slides. I am using full extension side-mount slides. A little lubricant from the ball bearings got on my hands and was eventually passed on to the plywood carcass. This is thin veneered plywood so I’m uncomfortable trying to sand the surface clean. Is there another way I can clean the surface prior to applying a finish? -- The plan is wrong; my finished piece is right. |
10 replies so far
#1 posted 01-22-2021 10:25 PM |
Wipe it down with lacquer thinner and lightly sand. Next time don’t put slides in until everything is finished |
#2 posted 01-22-2021 10:57 PM |
acetone or isopropyl alcohol would also be good solvents to remove the lubricant. Not sure what peso josh is peddling. Someone else can click the link… -- Earl "I'm a pessamist - generally that increases the chance that things will turn out better than expected" |
#3 posted 01-23-2021 12:03 AM |
Old teds at it again |
#4 posted 01-23-2021 12:04 PM |
After you clean it off using one or more of the methods suggested, test it by wiping a cloth spritzed with MS to see if it’s clean. This will mimic the appearance of a finished surface and let you know if you need to keep cleaning. -- Our village hasn't lost it's idiot, he was elected to congress. |
#5 posted 01-23-2021 12:11 PM |
Yeah, anyone posting a link that has less than ten post gets no clicks. I have noticed that the spammers have gone from random blah to using somewhat relevant content in their attempts. |
#6 posted 01-24-2021 03:00 AM |
This is interesting, all the tutorials I saw about slides said to finish after slides are placed (removing the slides, of course). Is it standard practice to finish first then install the slides? -- The plan is wrong; my finished piece is right. |
#7 posted 01-24-2021 03:01 AM |
Thank you all! I will follow these suggestions. -- The plan is wrong; my finished piece is right. |
#8 posted 01-24-2021 03:40 AM |
If I make a chest, I finish the case, top, and fronts. Then assemble everything. |
#9 posted 01-24-2021 11:48 AM |
I guess I don’t know what the “standard practice” is, but mine are always installed (and typically removed) before I finish the cabinet. But I’m a hobbyist and my approach (which had s always worked for me) may be different than a commercial shop might do. -- Our village hasn't lost it's idiot, he was elected to congress. |
#10 posted 01-24-2021 06:22 PM |
Like most things try the cleaning method you choose on a scrap first. The solvents may end up causing the grease/oil to spread. -- Les B, Oregon |
Forum | Topics |
Woodworking Skill Share
13194 |
Woodturning
2812 |
Woodcarving
569 |
Scrollsawing
416 |
Joinery
1892 |
Finishing
6339 |
7903 |
32747 |
CNC Woodworking
329 |
Hand Tools
6450 |
Jigs & Fixtures
1804 |
Wood & Lumber
7275 |
1632 |
Focus on the Workspace
2630 |
1272 |
Woodworking Trade & Swap
5412 |
LumberJocks.com Site Feedback
2396 |
Coffee Lounge
9656 |
