Forum topic by Brett | posted 01-22-2021 04:34 PM | 432 views | 0 times favorited | 8 replies | ![]() |
In his video for making a router table (https://youtu.be/2EYJdKTVeKM), Patrick Sullivan recommends the Dewalt 611 compact router. I’m having trouble finding that router at my local home centers. Can anyone recommend a similar compact corded router suitable for use in a router table? -- More tools, fewer machines. |
8 replies so far
#1 posted 01-22-2021 04:45 PM |
Bosch Colt is the usual recommendation: https://smile.amazon.com/Bosch-Colt-Variable-Speed-Router-GKF125CEN/dp/B01AX4A95S/ref=sr_1_2?crid=2OZJHNANM0QM&dchild=1&keywords=bosch+colt+router&qid=1611333667&sprefix=bsoch+colt%2Caps%2C191&sr=8-2 I have the Rigid 2401: https://www.homedepot.com/p/RIDGID-5-5-Amp-Corded-Compact-Fixed-Base-Router-R24012/100337039 in a table. It’s okay, some non-ideal things about it, but it works fine. |
#2 posted 01-23-2021 09:09 AM |
I have a few Bosch Colts from when they were what you could get. They are fine motors, with squirrelly clamping devices. Though they upgrade nicely with the addition of the plunge router base for them. It’s an extra cost. Being as you can get the DeWalt set of solid, and plunge bases for less than all the Bosch parts I believe they are now the stated set to get. Having both bases right off will become useful to you, almost guaranteed. Amazon has the set, comes from DeWalt. I’m sure other online venues do as well. -- Think safe, be safe |
#3 posted 01-23-2021 10:18 AM |
Curious to suggest a trim router for fixed table work. They look handy, but for a router table, I think I would go full size. Their advantage being smaller is for hand held use in tight spots. You can’t spin big cutters in small routers. Like all woodworking tools, every time I tried to go small or cheap, it cost more as I wind up buying the bigger tool anyway. My router table has a Tridon as it’s base functions like a lift if you take out the spring. Not cheap, but very nice. For hand held, I also have the Ridgid combo, plunge and fixed base. Works fine as far as I can tell. My “compact” ( 1/4 inch) is a 40 year old Craftsman. Thought it was pretty good until I got the big boys. Smaller than my half inch routers, a little bigger than the trim routers. At 1 HP, it does not bog down, but only spin small bits and light passes anyway. |
#4 posted 01-23-2021 01:36 PM |
The DeWalt 611 gets great reviews…..the only comment is that the body diameter may be too large for one handed use if the operator doesn’t have large hands. I found one at my local Lowes and picked it up to check the body diameter and it was too uncomfortable for me. The Makita RT0701C gets good reviews and I bought one. |
#5 posted 01-24-2021 04:14 AM |
I like my Bosch Colt. Ive got the newer version with the round base and it works really well. My no means am I an expert with a router and mostly use mine just for roundovers and flush cutting but it works well, its super easy to adjust and super easy to use. |
#6 posted 01-24-2021 04:24 AM |
The 611 is a great trim router. I have one, as well as the Porter Cable that looks just like it (sans variable speed). Excellent tools for handheld roundovers and lighter cuts. I wouldn’t choose a compact router for a table application though. You can’t use 1/2” shank bits, which is about half my collection. Plus you have a lot less power for the heavy joinery cuts. -- Willie, Washington "If You Choose Not To Decide, You Still Have Made a Choice" - Rush |
#7 posted 01-24-2021 01:39 PM |
The DW is an excellent router, but either Bosch or Makita will work. Height adjustment is going to be the most important factor especially in a table. -- Everything is a prototype thats why its one of a kind!! |
#8 posted 01-24-2021 04:49 PM |
I have a Bosch router and made the woodsmith compact table for it. |
Forum | Topics |
Woodworking Skill Share
13194 |
Woodturning
2812 |
Woodcarving
569 |
Scrollsawing
416 |
Joinery
1892 |
Finishing
6339 |
7903 |
32747 |
CNC Woodworking
329 |
Hand Tools
6450 |
Jigs & Fixtures
1804 |
Wood & Lumber
7275 |
1632 |
Focus on the Workspace
2630 |
1272 |
Woodworking Trade & Swap
5412 |
LumberJocks.com Site Feedback
2396 |
Coffee Lounge
9656 |
