Forum topic by BoilerUp21 | posted 01-22-2021 01:00 PM | 1253 views | 0 times favorited | 37 replies | ![]() |
What is everyones Top Ten List for Power tools if you could only have 10 to perform woodworking for the rest of your life and not buy another power tool? Ill Start: 1. Table Saw I guess you could go with a combo Jointer/Planer to free up a spot, but for what tool?...but ill stick with my list and say that this would give me the ability to do almost anything and fill in the gaps with hand tools. Are there others that should be considered? What would your list be? |
37 replies so far
#1 posted 01-22-2021 01:08 PM |
My list would be pretty much the same. I would swap out the jointer for a chainsaw. I would swap out the Domino for a trim router, or angle grinder. A corded hammer drill would also be high on my list, but not really necessary for woodshop woodworking. -- WWBBJ: the first to compare a woman´s cheek to a rose was a poet. The second, an idiot. Dali |
#2 posted 01-22-2021 01:09 PM |
That’s pretty close to my list save for the domino, too pricey for a one trick pony. Another thing to consider is the scope of work being done, someone who’s predominately building cabinets might need an altered list from someone building mostly jewelry sized boxes. A lathe could be added too, again depending on what work is being done. -- “I never in my life thought I would have to say this, but the proper role of government is not to fund the distribution of crack pipes,” Lauren Boebert |
#3 posted 01-22-2021 01:31 PM |
It depends entirely on what kind of woodworking you do. We did without any power tools for tens of thousands of years. If you happen to be a turner, then you need the lathe and BS. Some like to do fretwork, so a fretsaw is required. If I were to do any of my speakers in more than a one-off, a 5 axis CNC router and a TS would be al lI needed. You could cheat and claim a Shop-Smith as one tool. ( TS, BS, Lathe, DP) |
#4 posted 01-22-2021 01:34 PM |
Come to think about it, I would not want to be without my Fein HEPA vac. |
#5 posted 01-22-2021 04:33 PM |
You forgot a dust collector. You need multiple drills, routers and sanders. Multiple drills to pilot and drive without changing bits. Table router, handheld router, trim router and possibly a 2nd table router with a dedicated round over bit. Sometimes a dedicated router for dovetails. Multiple ROS’s for different grits so you’re not changing disks all the time. I have an OSS/OSB sander, disc sander, two ROS’s, knife sander, stationary belt sander, detail sander. Drill press bearings aren’t normally designed to carry lateral stress so using one with a sanding drum can be problematic and dust collection is an issue. Lathe. -- The hump with the stump and the pump! |
#6 posted 01-22-2021 04:37 PM |
While having a siesta today, I remembered that I use a belt sander quite alot. -- WWBBJ: the first to compare a woman´s cheek to a rose was a poet. The second, an idiot. Dali |
#7 posted 01-22-2021 05:32 PM |
I’ll post cause my will probably be a little different- 1 table saw Not including drill cause everyone should have that anyway. Also not including stuff you can get for less than 100$ Omission that really hurts-bandsaw |
#8 posted 01-22-2021 05:48 PM |
I could come up with a top ten list, but then I’d have to reserve the ability to update it as needed 8^) I’d be like Steve Martin in “The Jerk” when he leaves his corporation after going bankrupt. I’d even take the lamp. |
#9 posted 01-22-2021 05:56 PM |
Ya 20 would be a better number. :) |
#10 posted 01-22-2021 06:11 PM |
-- I collect hobbies. There is no sense in limiting yourself (Don W) - - - - - - - - Kenny in SW VA |
#11 posted 01-22-2021 06:16 PM |
As for power tools, i mainly use: Table saw I have others that get used occasionally, but my local lumberyard mainly carries S2S |
#12 posted 01-22-2021 06:21 PM |
Air compressor. -- The hump with the stump and the pump! |
#13 posted 01-22-2021 06:22 PM |
Do you consider a good solid workbench as a tool, I know I would have a tough time in the shop without one. I would swap out the Domino for a lathe or a workbench. -- Daniel, Pontiac, MI |
#14 posted 01-22-2021 06:38 PM |
Unless you have to plug your workbench in to use it, I think you get to keep it in addition to your 10 choices ;-) -- I collect hobbies. There is no sense in limiting yourself (Don W) - - - - - - - - Kenny in SW VA |
#15 posted 01-22-2021 06:40 PM |
Well you get to make a workbench with all the tools. |
Forum | Topics |
Woodworking Skill Share
13544 |
Woodturning
3010 |
Woodcarving
618 |
Scrollsawing
436 |
Joinery
2078 |
Finishing
6715 |
8188 |
34192 |
CNC Woodworking
384 |
Hand Tools
6775 |
Jigs & Fixtures
1921 |
Wood & Lumber
7617 |
1696 |
Focus on the Workspace
2749 |
1295 |
Woodworking Trade & Swap
5578 |
LumberJocks.com Site Feedback
2431 |
Coffee Lounge
9904 |
