Bandsaw as jointer?
Forum topic by Fugazni posted 01-21-2021 02:47 PM 299 views 0 times favorited 8 replies Add to Favorites Watch
View Fugazni's profile
Fugazni
3 posts in 35 days
01-21-2021 02:47 PM
In this video from Izzy Swan, he takes the sliding table off his Sawstop and attaches it to the bandsaw, and builds a plywood table on top of it with a rear fence. At the end of the video, he says he no longer has use for a jointer because he can face joint and edge joint with this setup. From my very limited understanding of bandsaws, the blade doesn’t produce a fine or accurate enough cut to do something like that.
Can someone explain how using a sliding table creates better results over using a fence? Could a setup like this really produce jointed surfaces?
https://youtu.be/PaUxTrn1p_E
8 replies so far
View Meisterburger's profile
Meisterburger
31 posts in 242 days
#1 posted 01-21-2021 02:56 PM
A sliding table could clamp a board so you reduce the human variability factors. Hand pressure to the fence, hand relocation on the workpiece during the cut, consistent angle of the workpiece, etc. I would be surprised if the edge quality was as good as a jointer could get you
View Kudzupatch's profile
Kudzupatch
109 posts in 2213 days
#2 posted 01-21-2021 03:03 PM
That would take a really well set up bandsaw. Most people seem to struggle with getting a bandsaw to cut straight lines.
I love my bandsaw and can cut straight lines with a fence but it would NEVER replace my joiner. You couldn’t do faces and your not going to get the smooth cuts you get with the joiner. I use mine to fine tune the width of boards, taking maybe a 1/32 off.
Maybe he has found a way but I have some serious doubts that this could ever replace a joiner for fine wood working.
-- Jeff Horton * Kudzu Craft skin boats* www.kudzucraft.com
View Aj2's profile
Aj2
3662 posts in 2802 days
#3 posted 01-21-2021 03:04 PM
He’s full of baloney. You tubers will make up anything to get views
-- Aj
View AMZ's profile
AMZ
285 posts in 394 days
#4 posted 01-21-2021 03:13 PM
- Aj2
Agreed! How many years of experience does he have under his belt?
I have three bandsaws, all three tuned, with one very, very tuned. Even the most tuned one (Grizzly 17”), the cut quality is only as good as 1/2 the depth side to side of the set teeth. I can easily resaw (did it just yesterday) a piece to 1/4” and needing only sanding to finish, but the surface was still subpar to a jointer.
View Robert's profile
Robert
4428 posts in 2485 days
#5 posted 01-21-2021 03:13 PM
Total BS.
View AMZ's profile
AMZ
#6 posted 01-21-2021 03:16 PM
I like watching Izzy, but only for entertainment! Though he claims some of the stuff he does is safe (such as using a table saw as a lathe), I disagree.
Anything on YouTube needs taken with a grain of salt. Some, like Stumpy, really know their stuff, but others, holy crap, where did they learn this or who taught them?
View Lazyman's profile
Lazyman
6617 posts in 2392 days
#7 posted 01-21-2021 03:34 PM
My guess is that what he really means is that he can get a straight enough edge which he can then use his table saw to get a glue joint ready edge or run it through a planer for the faces. You’ve also got to remember that his furniture designs are usually rustic so he probably doesn’t need a jointer anyway.
View AlaskaGuy's profile
AlaskaGuy
6393 posts in 3313 days
#8 posted 01-21-2021 03:46 PM
- Aj2
Agreed, If you read the comments below the video he gets a lot of wow factors. It’s like the videos of a pallet jack furniture builders videos who don’t have a clue about wood movement. They are building stuff that will self-destruct but the viewers go wild with compliments.
