Forum topic by JComer | posted 01-21-2021 02:46 PM | 406 views | 0 times favorited | 4 replies | ![]() |
This is my first segmented Turning, so I tried a design that seemed to be straight forward. I took the picture right after I finished sanding. I created several of the turnings as gifts but ran into an issue. After turning and sanding the barrel was completely smooth. You couldn’t feel the transition between the dark and the light wood. After sitting for a couple of days, the light wood appears to have expanded and there is an obvious ridge between the dark and the light layers. Is this normal? Should I need to let them sit and do a second round of sanding a few days later? Is there a technique I am unaware of? Any advice or suggestions would be appreciated. |
