Forum topic by SwampFox76 | posted 01-20-2021 01:43 AM | 547 views | 0 times favorited | 20 replies | ![]() |
Topic tags/keywords: bandsaw restoration Hello, |
20 replies so far
#1 posted 01-20-2021 01:49 AM |
Looks like a Craftsman. There was an old article in Popular Woodworking I think on fixing up that very same model 12” saw. |
#2 posted 01-20-2021 02:16 AM |
Looks like a Craftsman. +1 to it being a Craftsman, although it’s wearing powermatic colors ;) Cheers, -- Brad in FL - In Dog I trust... everything else is questionable |
#3 posted 01-20-2021 11:14 AM |
Looks half decent. Good buy. You can probably get some cool-blocks for it. Tires for sure. I might try to add DC ports to it and a belt guard. Big iron wheels, that’s great. |
#4 posted 01-20-2021 12:10 PM |
Thank you
Thank you. I looked up Crafstman bandsaw 1940’s and it is definitely that year. I’m thinking about changing the color of it anyway if I do I may be just going black with it.
In your opinion do you think it’s worth me fixing up? It looks like the tires would be about $26, a blade is about $10, cool blocks are about $14. I just got excited to add a band saw to my workshop and for $20 I thought it was a good deal, then I get it home and the next day I’m looking at it and start realizing that certain things didn’t look right to me so I came on here in search for some answers. |
#5 posted 01-20-2021 12:54 PM |
I don’t think you’ll find another band saw for less than $100, so I’d at least try and fix it up. Maybe one thing to check is the bearings – do they still sound good? Does it wind down smoothly and take a while to finally stop? -Brian -- Part of engineering is to know when to put your calculator down and pick up your tools. |
#6 posted 01-20-2021 01:16 PM |
I would definitely fix it up if you don’t have another bandsaw. Belt won’t cost much, tires should be a one-time expense and cool blocks will probably last the life of the saw in a hobby shop. In addition to checking the bearings, I’d also make sure the tension spring still has enough force to tension your blade (just have to put a blade on it and see). For $20 you did quite well :-) I wouldn’t worry about a blade guard unless you’re worried about kids or something being back there while you’re using it. There’s no danger of you sticking a finger in there while you’re sawing. -- I collect hobbies. There is no sense in limiting yourself (Don W) - - - - - - - - Kenny in SW VA |
#7 posted 01-20-2021 01:50 PM |
The bearings definitely still sound good. It takes about 6 to 7 seconds for it to wind down and stop.
Good to hear, I’m definitely going to fix it up then. I’ll see how the tension spring is when I get the blade on it. Any recommendation on the best versatile blade? Thank you to everyone who helped to provide me with information on this. |
#8 posted 01-20-2021 01:54 PM |
Would you be able to help me find that article? I tried a search but couldn’t find anything, not sure if you’re referring to an article in the magazine or something posted online. |
#9 posted 01-20-2021 02:07 PM |
I’d put a 1/4” 6 tpi skip tooth blade on it if it were me. But it’ll really depend on what you use it for most often. -- I collect hobbies. There is no sense in limiting yourself (Don W) - - - - - - - - Kenny in SW VA |
#10 posted 01-20-2021 06:05 PM |
Thank you |
#11 posted 01-20-2021 06:12 PM |
It was like 25 years ago. I don’t know how or if articles that old can be looked up online. In any case, the editors found the bones of the saw sufficient to warrant putting money and labor into it. The principles of setting up band saws are the same with all saws. The machine takes some time to learn about though. I read a book on them when I was starting out and even learned to cut dovetails on mine. |
#12 posted 01-20-2021 06:16 PM |
It looks very much like the Craftsman 12” that I have been using for fifty years. Actually mine may be an improved version of yours. -- Phil Allin - There are woodworkers and people who collect woodworking tools. The woodworkers have a chair to sit in. |
#13 posted 01-20-2021 06:28 PM |
I’m just happy to add a bandsaw to my workshop even if it requires some work to get it running again. |
#14 posted 01-20-2021 07:04 PM |
I have that exact same bandsaw. Craftsman— you can find a copy of the manual online. If not, PM me and I will send you the copy I have—if I can find the pdf. I had to buy a new blade guide for the top. Located a fellow on eBay who makes them. It was listed for another machine, but I bought it anyway. It “almost” worked—but a small piece needed to be altered. He did that for me—in exchange for my taking photos of it working on my bandsaw. It takes 80 inch blades. An old fellow gave me the machine about 5 years ago and I have used it since then. Only thing I wish it had was a slot/groove for a mitre saw guide to run on the top. But, I made a fence using a 2×4 and a bar clamp. That works well too. Max width blade for it is 3/4 in. I also run 1/4 inch and I think I have a 1/8 inch blade when I want to cut more detailed curves in things. All in all, it is a fine bandsaw and at this point, I don’t really want/need to replace it. |
#15 posted 01-20-2021 07:26 PM |
Do you know the model number so I can look it up? There are no markings on this bandsaw or else I wouldn’t be asking. |
Forum | Topics |
Woodworking Skill Share
13194 |
Woodturning
2812 |
Woodcarving
569 |
Scrollsawing
416 |
Joinery
1892 |
Finishing
6339 |
7903 |
32747 |
CNC Woodworking
329 |
Hand Tools
6450 |
Jigs & Fixtures
1804 |
Wood & Lumber
7275 |
1632 |
Focus on the Workspace
2630 |
1272 |
Woodworking Trade & Swap
5412 |
LumberJocks.com Site Feedback
2396 |
Coffee Lounge
9656 |
