Finish suggestions for padauk end tables?
Forum topic by LedRat posted 01-19-2021 02:03 PM 375 views 0 times favorited 15 replies Add to Favorites Watch
View LedRat's profile
LedRat
12 posts in 41 days
01-19-2021 02:03 PM
I’m planning on building some African padauk end tables and a TV console for my living room and I’m not sure what finish would be best. I prefer a natural wood feel and look, but need some protection from people setting drinks and food on the tables as well. I understand padauk’s color changes over time, but I’d like to preserve the color as much as possible.
I’m also considering using padauk for the lower structure and zebra wood for the tops (based on a box I made, and I really dug the look).
Poly may work well, but it’s ugly and therefore out of the discussion. But given the world of other options out there, what might you suggest?
Thanks in advance!
15 replies so far
View Sycamoray's profile
Sycamoray
55 posts in 249 days
#1 posted 01-26-2021 08:48 PM
Yes, poly is ugly. All the thick finishes which will provide meaningful protection from condensation, food, and UV light are layers of plastic which look ugly to some people. They sure look ugly to me.
Sorry, I have no real wisdom to share. I have simply accepted the choice between an ugly finish and wood that changes as it ages.
View SMP's profile
SMP
3429 posts in 914 days
#2 posted 01-26-2021 08:50 PM
Minwax Antique Oil applied via increasingly fine wet sanding has been the best tradeoff of looks vs protection that I have found.
View them700project's profile
them700project
293 posts in 2027 days
#3 posted 01-26-2021 08:51 PM
Padauk takes osmo pretty well for me
View pottz's profile
pottz
14799 posts in 1993 days
#4 posted 01-26-2021 09:55 PM
yeah sadly padauk will turn brown in time,the less light the better.i use oil finishes on pretty much all my work because i like the feel of the wood,but in doesn’t give the best protection against moisture from drinks.i did just try out rubio monocoat which is supposed to get complete protection in one coat,but it has a kind of dull flat look but does retain the natural look and feel of the wood.look up charles neils video’s he was a member here that passed last year but was a guru of finishing knowledge and made many tutorials on it.
LedRat
12 posts in 41 days
#5 posted 01-26-2021 09:57 PM
- them700project
Just looking up Osmo as I’m not familiar with them. But I see they make a variety of products, including a hard wax oil that sounds interesting. Is this what you use?
View Peteybadboy's profile
Peteybadboy
3068 posts in 2958 days
#6 posted 01-26-2021 10:30 PM
LedRat
Your post..
Rubio Mono coat leaves a wood feel and look, and protects from people setting drinks down on them. I have just tried it and that is exactly what it is for. I am not sure about protecting color.
This blood wood should get brown but will take time to be sure.
-- Petey
View PBWilson1970's profile
PBWilson1970
185 posts in 402 days
#7 posted 01-26-2021 10:47 PM
Not to put a damper on your project ideas, but be aware that if you are going to keep anything on the table top for long periods of time, the exposed part will turn brown while the covered part will stay red. Might look strange down the line.
Is there a UV inhibitor available that can be added to a finish?
Also, would a product meant for finishing wood on boats be worth a try since they are blasted with UV rays nonstop?
-- I love the smell of sawdust in the morning.
View splintergroup's profile
splintergroup
4669 posts in 2231 days
#8 posted 01-26-2021 10:56 PM
I’d offer up the “spar varnish” idea as well. “Real” stuff, not the Helmsman or other hardware store stuff. I like Epifanes but you need to thin it about 25%.
Two of the biggest sources that change the colors of wood are UV light exposure and oxidation.
View CaptainKlutz's profile
CaptainKlutz
4137 posts in 2503 days
#9 posted 01-26-2021 10:58 PM
Color/UV protection + food/water/alcohol protection + NO thick film finish? == IMHO definition of OXYMORON
https://www.wood-database.com/wood-articles/preventing-color-changes-in-exotic-woods/
What ever you use needs to have high levels of UV protection, and color will still change over time.
Will find least amount of UV protection from a simple oil, or oil/wax finish.
To met your stated goals I would use: 2k conversion varnish, oil based polyurethane, or one of newer WB polyurethane coatings that offers UV protection.
Finishing large furniture projects is usually best via spraying, so might as well contact you local industrial wood coatings distributor and ask them what they carry that will met your needs. There are too many mfg/brands with similar materials to list all the options available. Look for Renner, Gemini, Ml Campbell, or Axalta; in your area.
One of the toughest WB products that doesn’t need thick film for protection I have used is Renner 851 2K catalyzed acrylic urethane. This stuff is so tough after curing; you need to use silicon carbide or ceramic sand paper for any major removal. Garnet sand paper barely scratches the surface. One coat or about 2 mils is enough protection for kitchen cabinets, and looks ‘barely there’, similar to 1 coat of lacquer. Have not tested amount of UV protection, so YMMV.
Best Luck!
LedRat
12 posts in 41 days
#10 posted 01-27-2021 02:13 AM
Lots of food for thought here. I may rethink this whole padauk theme and just stain up something cheap and easy.
LedRat
12 posts in 41 days
#11 posted 01-27-2021 02:15 AM
- Peteybadboy
Nice tables!
View Jeff Vicenzi's profile
Jeff Vicenzi
63 posts in 398 days
#12 posted 01-27-2021 08:27 PM
As others have suggested, to preserve the wood color, the use of an exterior grade finish which has UV absorbers is best. Epifane brand is considered one of the best, but any exterior grade finish provides some UV protection. But realize these will only slow the color change down, not prevent it. If the piece gets any direct sunlight through window, it will be hopeless.
Because of this issue with paduak changing color, I now use mahogany that I dye with water base dye, followed by oil based stain, to simulate padauk. The advantage is that it is MUCH more color-fast (not too mention also much less expensive). I’ve attached a picture that compares Padauk to dyed African mahogany:
pottz
#13 posted 01-27-2021 08:40 PM
Because of this issue with paduak changing color, I now use mahogany that I dye with water base dye, followed by oil based stain, to simulate padauk. The advantage is that it is MUCH more color-fast (not too mention also much less expensive). I ve attached a picture that compares Padauk to dyed African mahogany:
- Jeff Vicenzi
man thats a pretty good match,food for thought.
LedRat
12 posts in 41 days
#14 posted 01-27-2021 09:21 PM
- Jeff Vicenzi
Oh, I like that! Good idea. Thanks.
splintergroup
#15 posted 01-27-2021 09:33 PM
Excellent solution!
Just be careful which dye you choose as many are also sensitive to fading under UV exposure (but they typically won’t shift to brown 8^)
