Forum topic by Wolfpacker | posted 01-19-2021 02:01 PM | 251 views | 0 times favorited | 5 replies | ![]() |
Topic tags/keywords: dining room table thin boards cherry I’m a rookie woodworker hoping to make a farmhouse-style dining room table for my family. I have some beautiful cherry lumber that my dad cut and stored 30+ years ago. Problem is, most of it is 7/8 inch thick in rough form, too thin for the typical edge-to-edge glue up for the top. I may have enough lumber to glue two layers together after jointing/planing, which would give me approximately 1 1/2 inch thickness. |
5 replies so far
#1 posted 01-19-2021 04:27 PM |
7/8 inch thick is not too thin for an edge-to-edge glue up. Also, gluing two layers together can lead to some nasty twisting and bowing. -- Half of what we read or hear about finishing is right. We just don’t know which half! — Bob Flexner |
#2 posted 01-19-2021 04:46 PM |
Yep, you can glue these boards edge to edge, using cauls to keep it all flat. If you want a thicker looking profile there are techniques to add a narrow strip of wood to the underside of the edge to double the apparent thickness. |
#3 posted 01-19-2021 05:05 PM |
I agree that your stock is thick enough to glue together into a tabletop. How large are you contemplating the top surface? As suggested, part of your solution can be additional wood around the edges to give the appearance of a thicker table top while using your 7/8” thick stock. This will take a little bit of planning in terms of the actual stock selection to ensure grain matching so that the look of the edges appears to be from thicker material and not a glue up. Do you have a plan for the ends of the table top? I’ll suggest bread board ends; those are in keeping with the farmhouse style and also eliminate the need to carry the “thicker stock illusion” to end grain. -- Ray |
#4 posted 01-19-2021 06:53 PM |
I recently (Decemeber) began a table project with the same issue. I face laminated my cherry to get a thicker table, which I’m glad I did. There was enough cup in the boards that after jointing, they would certainly have been too thin. I’m not done yet so I can’t tell you yet it was a complete success. So if you joint the boards and find you have 5/8 or 1/2 well then you’ll have to decide. -Paul -- I intended to be a woodworker, but turned into a tool and lumber collector. |
#5 posted 01-19-2021 08:24 PM |
A different solition might bee to have a MDF base and use your stock as thick veener with the MDF as the substrate. https://www.woodworkingtrade.com/types-of-wood-veneer-substrates/ -- It’s good to have an end to journey toward; but it is the journey that matters, in the end. - Ursula K. LeGuin |
Forum | Topics |
Woodworking Skill Share
13199 |
Woodturning
2814 |
Woodcarving
569 |
Scrollsawing
416 |
Joinery
1893 |
Finishing
6345 |
7906 |
32761 |
CNC Woodworking
330 |
Hand Tools
6453 |
Jigs & Fixtures
1804 |
Wood & Lumber
7276 |
1633 |
Focus on the Workspace
2632 |
1272 |
Woodworking Trade & Swap
5417 |
LumberJocks.com Site Feedback
2396 |
Coffee Lounge
9658 |
