Forum topic by jnswhit | posted 01-18-2021 02:45 AM | 290 views | 0 times favorited | 3 replies | ![]() |
I am modifying an old base cabinet in my kitchen and adding some drawers. It currently has doors and I would like to modify it, and substitute in drawers. This is going to require making the openings larger and adding some pieces to the face frame. The greatest challenge is in the fact the cabinet is not level anymore. I explored trying to level it, but it is build into the wall and would simply fall apart if I tried. Now to the real question, should I level the drawers and openings or follow the slope of the cabinet? This is about a 1/2” slop in 5 ft. I The top will be shimmed level and the drawers should be easy enough to level, but should I cut out the openings and add in face pieces and make it all level? It most likely will not be that drastic. One other concern I have with hanging the drawer on slides, if they are hung level will they bind. Any thoughts or experienced is appreciated. |
