Forum topic by klinkman | posted 01-17-2021 01:50 AM | 489 views | 0 times favorited | 12 replies | ![]() |
Topic tags/keywords: finishing arts and crafts Anyone have any ideas about how to keep stain from marking a dowel plug’s circumference? I was going to be alright living with the mismatched grain, but now that I’ve stained this sample, really not happy with the results. I purchased some nice quarter sawn Oak for a craftsman plant stand my wife wanted duplicated. I think I have a good formula for finishing. These dowel plugs are going to hose it up though. I’ve considered some paraffin wax to keep the stain out? seems iffy. Also considered shellac first, but the color doesn’t take as well. Seems like my only alternative at this point is lose the screws—at least it’s a long grain to long grain butt joint. I just hate to put all 7 of these parts together (to form the central column) with nothing more than glue. Any ideas are appreciated. thanks -- Klinkman, hand tool enthusiast |
12 replies so far
#1 posted 01-17-2021 03:05 AM |
Make it a feature. Use walnut plugs or some other highly contrasting wood. Alternatively, use a dowel or floating tenon instead of screws. |
#2 posted 01-17-2021 04:09 AM |
Stain has pigments that will settle into that joint. Dye doesn’t, and will color the wood with less emphasis on the joint. -- Half of what we read or hear about finishing is right. We just don’t know which half! — Bob Flexner |
#3 posted 01-17-2021 05:06 AM |
I’ve done what ” brtech” said and they looked pretty good. I’m talking about the plugs. Mel -- MEL, Kansas |
#4 posted 01-17-2021 11:14 AM |
lose the screws This^ -- “Wise men speak because they have something to say; fools because they have to say something.” – Plato |
#5 posted 01-17-2021 11:16 AM |
You’re way too picky. :-D -- Everything is a prototype thats why its one of a kind!! |
#6 posted 01-17-2021 01:55 PM |
Glue them in with hide glue. -- Bondo Gaposis |
#7 posted 01-17-2021 04:01 PM |
The stain loves end grain, which is ever so slightly exposed on the perimeter of the drill hole and plug. The only way I know to achieve your goal without changing your finishing schedule is to assemble and then plan on scraping/sanding away up to 1/16” to fully remove any exposed end grain areas. Alternatively, the suggestions to feature the plugs instead fo trying to hide them probably is easier. You can make them square, slightly proud (Greene & Greene style), contrasting, even from soft metals like brass or aluminum. |
#8 posted 01-17-2021 04:38 PM |
I did these about three years ago, no screws, no problems – except on one of them the very bottom sapele panel glue-up has separated about a millimeter. I just turn it to the wall and dont see it. -- WWBBJ: It is better to be interesting and wrong, than boring and right. |
#9 posted 01-17-2021 07:19 PM |
Some great suggestions everyone, thank you for your inputs and education from your experiences. I think I’m going to lose the screws to avoid the stain line all together. I’ll use a couple of 1/8 or 3/16 dowels on the mating surfaces for alignment during glue up. Adds another step but it should provide a simple and effective solution. Really appreciate everyone’s ideas. -- Klinkman, hand tool enthusiast |
#10 posted 01-19-2021 03:04 AM |
Another alternative where you absolutely need to use screws is to cut out a shape, e.g., a small tree, just as if you were putting in a bow tie, and then make the insert out of a contrasting wood the same color as your stain. More work though. |
#11 posted 01-19-2021 03:32 AM |
lose the screws most of the time no,but sometimes their needed.even the great sam maloof used screws in his furniture.but he didn’t try too pretend he didn’t and used contrasting plugs as part of the design. -- working with my hands is a joy,it gives me a sense of fulfillment,somthing so many seek and so few find.-SAM MALOOF. |
#12 posted 01-19-2021 10:54 AM |
Agreed. I have no aversion to using screws where they’re needed, but in this situation they aren’t. It’s a simple long grain glue joint. More than strong enough without fasteners of any type. -- “Wise men speak because they have something to say; fools because they have to say something.” – Plato |
Forum | Topics |
Woodworking Skill Share
13199 |
Woodturning
2814 |
Woodcarving
569 |
Scrollsawing
416 |
Joinery
1893 |
Finishing
6344 |
7906 |
32761 |
CNC Woodworking
330 |
Hand Tools
6453 |
Jigs & Fixtures
1804 |
Wood & Lumber
7276 |
1633 |
Focus on the Workspace
2632 |
1272 |
Woodworking Trade & Swap
5417 |
LumberJocks.com Site Feedback
2396 |
Coffee Lounge
9658 |
