Wisteria furniture
Forum topic by whitehawk posted 01-15-2021 05:11 AM 368 views 0 times favorited 6 replies Add to Favorites Watch
View whitehawk's profile
whitehawk
2 posts in 42 days
01-15-2021 05:11 AM
Topic tags/keywords: wisteria interior design natural look furniture organic root furniture
Hi there
I have salvaged a huge piece of wisteria. 6 inches diameter 6 ft tall plus. I’d like to dry it and protect it .. and keep it as one piece and incorporate into a threshold maybe .. any ideas of how best to dry and what’s best to use to seal/protect it bark on. ??
Wishing y’all many thanks and a great 2021!
View Lazyman's profile
Lazyman
6617 posts in 2392 days
#1 posted 01-15-2021 06:02 AM
Are you saying you want to use it as a log? If you plan to cut it into boards at some point it is better to do that now. I don’t know anything about wisteria but logs in general will crack worse in log form and they will take much longer to dry too. Provide a little more info about what you would like to do with it.
Paint a thick coating on the end to reduce cracking, Anchorseal works great and the Rockler green wood sealer is the same stuff for much less.
View therealSteveN's profile
therealSteveN
7210 posts in 1578 days
#2 posted 01-15-2021 12:52 PM
Google Woodweb. It is a huge forum, database with a heavy influence toward those who cut down, and then manage all forms of things wood like. They may well have a Wisteria forum buried deep inside of their knowledge base.
Some of the arborist types there could probably get you some good answers if you don’t get many absolutes here. I think you best answers may well come from them, as I have been buying wood, lumber, and sheet goods for a long time and can’t remember ever seeing Wisteria being sold, either whole, or as lumber.
Best of luck, if you get something made with it, post a pic.
-- Think safe, be safe
Lazyman
#3 posted 01-15-2021 03:20 PM
Or search Lumberjocks. There are a couple of forum topics and projects listed here.
View mpounders's profile
mpounders
988 posts in 3900 days
#4 posted 01-15-2021 04:25 PM
As they said above, paint the ends to keep it from splitting. Air drying usually takes a year per inch of thickness and that usually applies to boards where the surfaces are exposed. Wisteria has a very pretty color and grain, at least the piece I cut down did. The bark is still on one carving I did, not very thick and seems to stay tightly attached. Just keep it some place dry, where air can circulate around it.
-- Mike P., Arkansas, http://mikepounders.weebly.com
View torus's profile
torus
525 posts in 1417 days
#5 posted 01-15-2021 05:50 PM
https://www.lumberjocks.com/mpounders/blog/30725
-- "It's getting better..." - put this on my RIP stone!
whitehawk
2 posts in 42 days
#6 posted 01-17-2021 02:57 PM
Handy suggestions thank you, ill check out woodweb too ..
Want to keep it as much as one piece original .. beautiful art ..
