Forum topic by CASJOE | posted 01-15-2021 12:28 AM | 567 views | 0 times favorited | 4 replies | ![]() |
Topic tags/keywords: plywood baltic birch 18 ply Howdy! I use a lot of Baltic Birch in my shop and love it. Mostly I use 1/4” but that’s only because I can only find 1/8” sheets in 60” x 60”. Does anyone know if it is possible to buy 1/8” baltic birch ply in 4’ x 8’ or even 5’ x 10’? I can get 1/4” in either of these sizes but not 1/8”. Alternatively, does anyone have a recommendation for larger sheets of 1/8” plywood that have similar structural quality to the baltic birch? All of the other 1/8” ply I’ve ever seen has a super thin veneer over a pretty crappy core. Thanks! |
#1 posted 01-15-2021 08:49 AM |
Thin structural plywood is common place in home built aircraft, WWII aircraft, and radio control boat/aircraft hobby. Search your favorite site for ‘aircraft plywood’ and 1/16-1/4 is easy to find. Have used Aircraft Spruce & Specialty in past for 5×10 wing skin plywood, but there are many other suppliers. If you live in area with several small air fields, have a WWII plane club, or a home built aircraft club in area; occasionally will find the a commercial lumber yard nearby carries some of the MIL spec grades of aircraft plywood for community. All you can do is call every one and anyone advertising plywood in your area. Lumber sourcing varies greatly by regional area. If your profile included you city, state; might have some one close share local sources? Best Luck. -- If it wasn't for bad luck, I wouldn't have no luck at all, - Albert King - Born Under a Bad Sign released 1967 |
#2 posted 01-15-2021 01:01 PM |
Both the Rockler, and WoodCraft stores near me stock it. But it is 5×5’ or smaller panels. If I were looking for it, I would start asking my local suppliers of BB ply if they can’t order it in for me. Going based on that I am happy with the product they are currently selling me, over just buying online from someone I had never dealt with. -- Think safe, be safe |
#3 posted 01-15-2021 05:04 PM |
The outfit that put in our Quartz used 1/8” strips to make a template. I contacted them and bout 3 sheets of 1/8” plywood from them. It’s sitting the back of my garage behind my boat waiting to be used for something. You might contact countertop shops in your area for something similar. This stuff is obviously some sort of mahogany. |
#4 posted 01-15-2021 09:44 PM |
Probably Okume plywood, most commonly sold as marine grade plywood due light weight and easy to bend: https://forestplywood.com/blog/plywood-uses/what-is-okoume-plywood-and-how-can-i-use-it/ Could be Luan skin plywood, but tends to be heavier and high ply count does not bend as easy as Okume. There are enough different types of plywood available, it will make you head spin. Cheers! -- If it wasn't for bad luck, I wouldn't have no luck at all, - Albert King - Born Under a Bad Sign released 1967 |
Forum | Topics |
Woodworking Skill Share
13199 |
Woodturning
2814 |
Woodcarving
569 |
Scrollsawing
416 |
Joinery
1893 |
Finishing
6343 |
7906 |
32761 |
CNC Woodworking
330 |
Hand Tools
6453 |
Jigs & Fixtures
1804 |
Wood & Lumber
7276 |
1633 |
Focus on the Workspace
2632 |
1272 |
Woodworking Trade & Swap
5417 |
LumberJocks.com Site Feedback
2396 |
Coffee Lounge
9658 |
