Forum topic by SleepingFox | posted 01-15-2021 12:27 AM | 590 views | 0 times favorited | 12 replies | ![]() |
Topic tags/keywords: question veneering Hello, I’ve noticed that Lee Valley’s hide glue seems pretty inexpensive, dare I say cheap. Normally when I buy inexpensive stuff it doesn’t work so well. Has anyone tried this stuff and can give it a review? I have a project that has some fancy veneering and was thinking of giving it a try. Thanks |
12 replies so far
#1 posted 01-15-2021 01:37 AM |
talk to lj’s (shipwright) he has worked with hyde glues a lot and does a lot of marquetry using veneers. -- working with my hands is a joy,it gives me a sense of fulfillment,somthing so many seek and so few find.-SAM MALOOF. |
#2 posted 01-15-2021 05:10 AM |
Are you referring to their Antique Restorer’s Veneer Hide Glue? $17 per pound is far from inexpensive. Compare that to Old Brown Glue’s store where a pound is $10 and it goes down to around $8 per pound in quantity. -- Half of what we read or hear about finishing is right. We just don’t know which half! — Bob Flexner |
#3 posted 01-15-2021 05:39 AM |
Yup that’s the stuff:
Thanks for putting me onto this. I hadn’t seen it before. Unfortunately to get a pound shipped to me (Canada) it’ll be 52USD after shipping (but before whatever customs charges me) making it about $68CAD for a pound. Lee Valley is still looking pretty cheep to me but I see your point. Do you use this? If so what does it cost you to get it shipped? Thanks again |
#4 posted 01-15-2021 08:43 PM |
I know all about shipping glue from California to Canada. Last time I bought from Patrick (ASFM) the shipping was more than the glue. -- Paul M ..............the early bird may get the worm but it’s the second mouse that gets the cheese! http://thecanadianschooloffrenchmarquetry.com/ |
#5 posted 01-15-2021 08:54 PM |
192 gram is the preferred strength, open time etc. for lutherie. Paul is certainly correct on the 260. Some folks add urea to the 260 to increase open time. This takes some experience as it can have negative effects on the glue. -- Darrel |
#6 posted 01-16-2021 12:46 AM |
Thanks a bunch Paul, I’ll give it a go. Also, I love your vice bench! I’ve been eyeing it for a while and am halfway through building my own :)
That’s interesting, I’m going to start with just the glue but will keep this in mind if I need option with open times. Thanks :) |
#7 posted 01-16-2021 12:53 AM |
Funny you should mention my bench. Yesterday after all this time I had occasion for the first time to use the two wagon vices together as intended. Just in case someone thinks I’m off topic, the panel is assembled with ~180 gram HHG some of it with rub joints. -- Paul M ..............the early bird may get the worm but it’s the second mouse that gets the cheese! http://thecanadianschooloffrenchmarquetry.com/ |
#8 posted 01-16-2021 01:02 AM |
paul this is lj’s,there is no “off” topic.every thread goes off topic at one point,it’s a given-lol. -- working with my hands is a joy,it gives me a sense of fulfillment,somthing so many seek and so few find.-SAM MALOOF. |
#9 posted 01-16-2021 01:31 AM |
Looking good Paul! -- Darrel |
#10 posted 01-16-2021 02:17 AM |
Getting back on topic, is there a particular use for hide glue? I’m totally ignorant and this is an opp for a brief tutorial… -- Bstrom |
#11 posted 01-16-2021 02:31 AM |
Paul has had the most extensive use and experience but I’ll throw my more limited experience out in a truncated form so he doesn’t have to always reply. :) Pros: 1. Hot hide is extremely strong, stronger than the wood like the majority of wood glues. 2. Hot hide glue is glass hard and won’t creep like the majority of wood glues including epoxies over time and if particularly, in a stressed joint. 3. Hot hide glue is able to be released using a combination of heat and moisture. Heat alone will not cause it to release. This is what gives a great advantage for musical instruments during a “hot car event” which will cause many modern wood glues to release. (Instrument builder, sorry). 4. Adhesion: Hot hide has been known to take away glass chips when trying to scrape it from a glass surface. It also will adhere to itself when old hide glue exists in the ,rare instance within this group, of a failed joint. :). It doesn’t need to be totally cleaned from the surface like a PVA as PVA will not adhere to old PVA. Cons: 1. Short open time. Joints need to be prepped and ready. A hair dryer or heat gun as well as a warmer environment helps to extend open time. 2. That’s about it. Hide glue is still the best! :) -- Darrel |
#12 posted 01-16-2021 06:28 AM |
Pretty well said. ... I’m getting tired. What was the question again? -- Paul M ..............the early bird may get the worm but it’s the second mouse that gets the cheese! http://thecanadianschooloffrenchmarquetry.com/ |
Forum | Topics |
Woodworking Skill Share
13194 |
Woodturning
2812 |
Woodcarving
569 |
Scrollsawing
416 |
Joinery
1892 |
Finishing
6339 |
7903 |
32746 |
CNC Woodworking
329 |
Hand Tools
6450 |
Jigs & Fixtures
1804 |
Wood & Lumber
7275 |
1632 |
Focus on the Workspace
2630 |
1272 |
Woodworking Trade & Swap
5412 |
LumberJocks.com Site Feedback
2396 |
Coffee Lounge
9656 |
