Forum topic by wilschroter | posted 01-14-2021 02:16 PM | 302 views | 0 times favorited | 8 replies | ![]() |
I’ve got a Jet DC-1100VX-CK dust collector that I’d like to get off the rolling base and move to a wall mount design that would allow me to organize my space a bit better. Does anyone have experience in taking their dust collector off the base and changing it to a vertical orientation? |
8 replies so far
#1 posted 01-14-2021 02:50 PM |
I took mine off of the base to mount over a super dust deputy. I built a fame out of 2×4s, and mounted the blower on what is in essence a wall. Mounting to a wall of your home wound raise a concern about vibration and noise. If that is no concern, it should work fine. It’s very heavy and will probably need the wall to be beefed up a little. |
#2 posted 01-14-2021 02:56 PM |
Yup I have exact same blower. Before I did it I called Jet support and they said no problems. -- Everything is a prototype thats why its one of a kind!! |
#3 posted 01-14-2021 03:00 PM |
@robert this is exactly what I’m looking for. How bad is that vibration over the walls when it fires up? I’m going to be loading onto an exterior wall that is 2 floors down from my master bedroom (in the basement). Obviously that vibration isn’t going to be zero, but I’m trying to get a feel for how bad is bad. |
#4 posted 01-14-2021 04:21 PM |
I exhaust outside so my wall hanging dc is a little bit different. But there is little or no vibration. The wall studs are 2×6. I added 2 guy wires attached to the impeller brackets and ceiling rafters for added support. |
#5 posted 01-14-2021 04:36 PM |
I’ve heard in the Fine Woodworking podcast of someone mounting one to the ceiling. They flipped the ring housing over so the bag remains down. -- Just a Duffer |
#6 posted 01-14-2021 04:45 PM |
@bob5103 is it the exhaust that is generating the bulk of the noise? Re: the fan itself isn’t the culprit so to speak? Hard for me to tell given I just see a big thing making noise. |
#7 posted 01-14-2021 08:54 PM |
Since I exhaust outside the majority, guessing 75%+, of the noise is also exhausted outside. I don’t have any close neighbors, so I do not have to worry about disturbing anyone. |
#8 posted 01-24-2021 12:42 AM |
I have one of the small floor units, it worked but was always in the way. I made a frame to mount it to after removing the wheels. It isn’t the prettiest unit but it sure works and it’s movable. The frame was designed to raise and lower, but once I found the sweet spot it hasn’t had the elevation changed. |
Forum | Topics |
Woodworking Skill Share
13142 |
Woodturning
2784 |
Woodcarving
564 |
Scrollsawing
413 |
Joinery
1870 |
Finishing
6303 |
7859 |
32546 |
CNC Woodworking
325 |
Hand Tools
6421 |
Jigs & Fixtures
1785 |
Wood & Lumber
7245 |
1614 |
Focus on the Workspace
2616 |
1267 |
Woodworking Trade & Swap
5395 |
LumberJocks.com Site Feedback
2394 |
Coffee Lounge
9628 |
