Performax Jet 22-44 Dust Shroud Hood
Forum topic by Ruscal posted 01-13-2021 08:21 PM 212 views 0 times favorited 5 replies Add to Favorites Watch
View Ruscal's profile
Ruscal
67 posts in 152 days
01-13-2021 08:21 PM
Any suggestions to source a replacement dust hood? Jet has them for 300+ which is ridiculous. This is to fit the drum sanders with the over the drum support and the feed table that raises and lowers. I assume the castings for the overhead support that the newer hoods snug to are all the same – 1980’s Performax to the late model Jet. I have three of the older USA made Performax 22-44 3 legged and 4 legged and they are the same. https://s3.amazonaws.com/vs-lumberjocks.com/qmw2yay.jpg!
-- Have a hobby? You should have a business.
5 replies so far
View Loren's profile
10938 posts in 4622 days
#1 posted 01-13-2021 08:23 PM
I made one out of wood when I had a Performax. It wasn’t too difficult.
Ruscal
#2 posted 01-13-2021 09:12 PM
Trying to avoid a wood one. Thinking about PVC board if I shop make one. But prefer OE. Two of these drum sanders I bought cheap to fix and flip.
View Lazyman's profile (online now)
Lazyman
6362 posts in 2361 days
#3 posted 01-14-2021 03:38 PM
I’ve seen people who have built their own drum sanders use large PVC pipe. Here is one from Shipwright.
Ruscal
#4 posted 01-14-2021 05:07 PM
Lazyman – that’s a cool homemade one. I’m needing OE or OE lookalike source though to resell machines. Or I’m going to make jigs and heat bend PVC board to make a couple similar to OE. Maybe I’ll go into business, could fab some with twin 4” or a 6” opening. There are a lot of these sanders out there, and the covers are prone to damage. And the early ones with 2” ports lack suction.
Lazyman
#5 posted 01-15-2021 05:00 AM
You could call it the new and improved cover. :-) It would probably work better and be more durable than the stock one.
