An odd question
« back to Scrollsawing forum
Forum topic by mikeber posted 01-04-2021 12:15 AM 647 views 0 times favorited 8 replies Add to Favorites Watch
View mikeber's profile
mikeber
53 posts in 2104 days
01-04-2021 12:15 AM
Topic tags/keywords: question scroll saw
I’ve owned and used many tools. However I never used a scroll saw so my question could sound weird to those experienced with the tool.
In case I need to cut a perfect square out of a piece of plywood, does any scroll saw come with a fence and/or miter gauge? I looked at several models, but none seem to offer these accessories. Are there after market sources? (I do get that much scrolling is freehand, but sometimes I need to cut precise lines and angles).
8 replies so far
View Jimarco's profile
Jimarco
67 posts in 2351 days
#1 posted 01-04-2021 01:33 AM
My 2 cents…. If you need a perfect square, precise lines or angles on the outer edge(s) use a different saw. A table saw, table saw with mitered sled and miter saw come to mind then go back and do your scroll work. It’s possible for a person who is very good with the scroll saw could do it? I’m not that person so I would make it easy for myself.
View SMP's profile
SMP
4833 posts in 1149 days
#2 posted 01-04-2021 01:38 AM
Yeah its the same as with hand saws. You don’t want to use a coping saw to cut a straight line.
View Rich's profile (online now)
Rich
7459 posts in 1833 days
#3 posted 01-04-2021 01:41 AM
How large is the square?
A jigsaw can cut out an opening in a board. It also can be used with a straight edge to get a clean, straight cut.
View pottz's profile
pottz
20680 posts in 2228 days
#4 posted 01-04-2021 01:51 AM
scroll saws are not what you wanna use for perfection,just consider the blade itself,theres no way keep it on a straight line,just why you wont find a miter gauge or fence on them,their made for cutting out intricate shapes.as rich said use a jigsaw.
mikeber
#5 posted 01-04-2021 02:06 AM
- Rich
In this case I was looking at a 3×3” cutout. For another project it was a 5” diamond shape. And since I was looking to purchase a scrollsaw, I asked myself why not use the scroll saw to cut these. Anyway, I do understand that’s not how the market for these tools developed.
View ddockstader's profile
ddockstader
225 posts in 4505 days
#6 posted 01-04-2021 07:57 AM
On the other side of the question, I use my scroll saw to cut straight lines all the time. Scroll saws can cut perfectly straight lines – if you know how to handle them. Just like a band saw, scroll saws (specifically the blades) often have some drift. But if you can cut a straight line with a band saw, you can cut one with a scroll saw. You don’t need a fence. All you need is good vision and hand-eye coordination.
View Ruscal's profile
Ruscal
120 posts in 422 days
#7 posted 01-04-2021 02:00 PM
Rough cut first. Then a router with a template or router table along fence with stop blocks, then just clean up the corners.
-- Have a hobby? You should have a business.
View Woodtodust's profile
Woodtodust
85 posts in 3081 days
#8 posted 01-04-2021 02:41 PM
Just to add to what Russel Hayes said—-you can also use files/rasps to true up a square opening that small after cutting with the scroll saw. I have also scribed lines to the appropriate dimension and used chisels to true everything up by placing the chisel in the scribe line. The same as truing up a hinge mortice or a through mortice.
There are always many ways to skin the proverbial cat.
-- Bill...Richmond Hill, GA--"83% of all statistics are made up."
