Forum topic by Jopldangla | posted 01-01-2021 08:41 PM | 629 views | 0 times favorited | 18 replies | ![]() |
I am hunting for a used planer. I know I want a 15” or larger and brand new will break the bank. Questions Thanks folks. |
18 replies so far
#1 posted 01-01-2021 08:54 PM |
1. get some Planer Pals I’ve always got by fine with straight knives. |
#2 posted 01-01-2021 11:58 PM |
I would think unless it’s a death you won’t see any Heli head planers, or Jointers on the secondary market, unless you have a dealer like Mueller that does a lot of swap sales to people working in industry. Edward B Mueller in Cinci. https://www.muellerco.com/used-machinery/ You might want to add a general location in case someone local has equipment to sell. I use SW Ohio, it doesn’t need, or would you want to use real addresses online. But most likely someone with a planer or jointer to sell is looking for a local sale, not shipping. -- Think safe, be safe |
#3 posted 01-02-2021 12:30 AM |
There are aftermarket helical head cutters you can install on a used planer. https://shelixheads.com/SHELIX-heads_for_Planers Buy whichever planer you like and install the helical cutter head when you are able. |
#4 posted 01-02-2021 01:13 AM |
+1 Straight blades work fine. IMHO – Don’t NEED carbide edged segmented cutter head unless running mostly figured woods, high daily volumes, and/or hardest exotic species. Takes < 1hr to install a set of straight knives; after you learn how. As far as pricing: 1) Overworked commercial tools, or hobby tools ignored for so long they barely run; both need rebuilds and sell for < $400. Personally never paid more than $325 for rebuild tool, most were ~$200 or less. 2) Fairly priced tools sold by hobbyist in running shape, usually $500-$800 depending on condition. 3) Hobbyist sold tools with gold plated prices ($900+). Some are brand new and likely worth 60-70% of retail, to someone who needs that “new car” smell. But most are machines with minimal use over 10-20 years, zero maintenance, and barely worth $500-$700. Everyone of the $1000+ planers I have seen that are more than 10 years old, have neglected maintenance. Biggest issue is forgetting to oil the in/out feed roller bushings. The bushing bores end up oval shaped due spring pressure; and this makes setup and cut uniformity problematic. Yes, they still run/plane; but will have obvious feeding issues. Found a couple expensive ones missing oil in gear box too. :-) Notes: - Segmented carbide cutter heads need more HP for same cut depth as straight knife machine. Straight knives will take full width 1/8” deep cut in one pass with 2HP. Might groan on hardest woods, but most will do it. Upgrading a 2HP 15” planer with new head will stall a 1/8” cut, and limits max cut to ~1/16” per pass. Even with 3HP, segmented heads do not have chip clearance for more 3/32 cut depth and bind up on softer woods at higher feed rates. - 15” planers have high demand in used market. Most 15” planers with < $600 prices sell a few minutes after listing. Listing prices of $600-$900 take about 2-3 days to disappear, but tend to have a wait list of buyers after 24 hours has passed. If a tool sits on CL/FB for more than a week, the entire market believes it is over priced. Here is a blog post with more thoughts on used tool pricing. - If price is right, fixing a planer is definitely worth it. Have rebuilt half dozen 15” Taiwan made planers over last couple decades. Can replace every bearing in machine (~20), replace belts, and rubber out feed roller for < $250 in parts. Takes me 2-3 hours to tear down, 2-4 hours to de-rust table/parts, about 4 hours to reassemble once I get parts; , and another 1-2 hours to setup machine table, roller, and cutter heights. Pop in a set of new blades, and have machine ready for another 20+ years of hobby use. - Powermatic is made in same factory as other guys. The elevated pricing fades as soon as Powermatic ‘no questions asked’ warranty expires, IMHO. Have used same Grizzly/Jet parts to repair Powermatic 15” as I used on a Delta or lessor known brand like AMT or General. Apologies if you think paying for gold paint makes it a better machine. Only difference is US designed, Taiwan made motor/motor starter; and special Powermatic quality specifications. These things mean very little after 10-15 years, when machine needs service parts, as Powermatic as discontinued parts for these older machines. The Taiwan made planers ALL have decent quality levels. #IAMAKLUTZ not an expert. But my luck as let me stumble across 15” planers cheap, and simply passing along what I learned. My last bargain find and planer upgrade was Jet 20”. :-) YMMV Best Luck. -- If it wasn't for bad luck, I wouldn't have no luck at all, - Albert King - Born Under a Bad Sign released 1967 |
#5 posted 01-02-2021 02:40 AM |
Changed my mind, buy the least expensive Taiwan made planer you can get your hands on and convince CaptainKlutz to rebuild it for you ; ) |
#6 posted 01-02-2021 03:08 AM |
I have a planer for sale -- Regards Rob |
#7 posted 01-02-2021 03:21 AM |
if you can afford buy a heli head,it is well worth it.and klutz oh my god he means well but he’‘l bore you too death with more info than any man would ever need…........im joking,he’s a wealth of information that you can take from.but seriously heli heads are smoother and quiter and easier too change blades.i dont think there is a down side. oh that rob guy be careful,ive heard bad things,best too avoid-lol. -- working with my hands is a joy,it gives me a sense of fulfillment,somthing so many seek and so few find.-SAM MALOOF. |
#8 posted 01-02-2021 03:39 AM |
That looks like littleblackducks shop. Rob your selling his stuff again? |
#9 posted 01-02-2021 03:49 AM |
probably he’s good at that-lol. -- working with my hands is a joy,it gives me a sense of fulfillment,somthing so many seek and so few find.-SAM MALOOF. |
#10 posted 01-02-2021 07:56 AM |
Man… such a wealth of information in here. It looks like at my price point I am in the straight knives world, now to focus my efforts on that front. Are there any models or brands to stay away from? It sounds like powermatic is a good brand but not really worth the money at my price point since it’s all about warranty at this age and there isn’t any sense in paying a premium for a badge. I was fortunate, however to pick up a grizzly 8” jointer with helical head for $700 recently. The jointer was mfg in 2019 and had little use. It did have some rust or stain stains on the tables which cleaned up with some bartenders friend. |
#11 posted 01-02-2021 11:29 AM |
-- Regards Rob |
#12 posted 01-02-2021 11:30 AM |
-- Regards Rob |
#13 posted 01-02-2021 01:13 PM |
I doubt you’re going to find many used helical heads. 1 – on mine (Grizzly 20”) it’s a half day job. But thats me setting blades to .001”, adjusting pressure bar and rollers. Other machines might be easier. 2 – very ample budget you should be able to pick on up $5-800 Aftermarket helical heads can cost as much as the whole planer so I don’t recommend that. A straight blade planer will work. It’s when you let the blades get dull and take too heavy a pass you get in trouble on certain lumber like oak or figured. I think a lot of people view a planer as a surfacer, which it is not it is a thicknesser. Big difference. That said, Imjust changed the knives in mine and the wood will come out like glass but only a little while. IMO a drum sander is the best money you can spend in just about any shop. I’d rather have a cheap planer and a drum sander than a helical head. -- Everything is a prototype thats why its one of a kind!! |
#14 posted 01-16-2021 12:00 AM |
Revisiting an older thread of mine. I came across a shopfox, circa 2011, 20” straight knife W1754 planer. I haven’t seen it in person, but it wasn’t used in some high volume shop, but rather used in a hobby shop. Has anybody used this machine? My research seems to indicate it is basically the same machine as the grizzly..powermatic…insert name here… They are also selling a Delta drill press 17-900 and band saw 28-206 (14”) and drum sander 31-250… thinking I may be able to get it all for around $1500-1600… would you just stick with the planer at $800, and try to get better finds on the other equipment? |
#15 posted 01-16-2021 12:00 PM |
If that planer is in good shape (and you can deal with it, weight…electrical, etc.) it’s a good buy IMHO. Personally I would value the DP (I have one) around $250, and the BS somewhere in the $400 range. But those are my guesses, without seeing anything. The value of tools vary greatly depending on a never ending list of reasons….so what’s important is whether they are worth it to you. -- Our village hasn't lost it's idiot, he was elected to congress. |
Forum | Topics |
Woodworking Skill Share
13199 |
Woodturning
2814 |
Woodcarving
569 |
Scrollsawing
416 |
Joinery
1893 |
Finishing
6345 |
7906 |
32761 |
CNC Woodworking
330 |
Hand Tools
6453 |
Jigs & Fixtures
1804 |
Wood & Lumber
7276 |
1633 |
Focus on the Workspace
2632 |
1272 |
Woodworking Trade & Swap
5417 |
LumberJocks.com Site Feedback
2396 |
Coffee Lounge
9658 |
