Router templates
Forum topic by Andybb posted 12-28-2020 08:01 PM 1397 views 0 times favorited 69 replies Add to Favorites Watch
View Andybb's profile
Andybb
3166 posts in 1613 days
12-28-2020 08:01 PM
Topic tags/keywords: resource question router
Looking for a source for a variety of router inlay templates (specifically a cross for a cremation urn inlay)
Thanks in advance.
-- Andy - Seattle USA
69 replies so far
View HokieKen's profile
HokieKen
16670 posts in 2148 days
#1 posted 12-28-2020 08:15 PM
Lots of interesting things at Tarter Woodworking.
-- I collect hobbies. There is no sense in limiting yourself (Don W) - - - - - - - - Kenny in SW VA
View Rich's profile
Rich
6535 posts in 1599 days
#2 posted 12-28-2020 08:19 PM
- HokieKen
Looks like a good source. Of course, for just a few dollars more†, you could invest in the Shaper Origin and your inlays would only be limited by your imagination.
† OK, a lot of dollars more.
HokieKen
#3 posted 12-28-2020 08:25 PM
And then a lot more dollars on top of those ;-)
But, Rich reminded me how I got my inlay template for my maker’s mark:
Which was to hit up a buddy with a CNC and have him cut me one in some 1/4” acrylic. If you can’t find the exact size/design cross you need, post on here. I imagine someone with a Shaper Origin or a traditional CNC can accommodate you :-)
View Rich's profile
Rich
#4 posted 12-28-2020 08:40 PM
- HokieKen
Excellent idea!
Andybb
#5 posted 12-28-2020 08:53 PM
- HokieKen
Yep. Thanks. Just got off the phone with them. They have a 3 layer cross kit for $22 that can either layer or make a cross 2 3 or 4” tall. seems like a plan since you really get multiple possible combinations.
View 987Ron's profile (online now)
987Ron
378 posts in 326 days
#6 posted 12-28-2020 09:02 PM
for my string and berry inlay I make my own. Not hard to do. These are simple ones. More complicated ones as Ken has said.
-- It's not a mistake it's a design opportunity
HokieKen
#7 posted 12-28-2020 09:05 PM
- HokieKen
- Andybb
Very nice. I’ve always liked their multiple layer system but haven’t been able to convince myself that I’d ever use any of them more than once. I guess if I had a broader audience/customer base than just close friends and family I’d be more inclined.
Andybb
#8 posted 12-28-2020 09:10 PM
I guess if I had a broader audience/customer base than just close friends and family I d be more inclined.
- HokieKen
Ha. I have the same audience/customer base as you do but the base is getting smaller cuz they’re dying. 3rd urn this year. Best friend’s wife but he wants a cross and I ain’t good enough to do it perfectly with a chisel and don’t know anyone with a CNC. I could use my laser engraver but want something nicer. Known her for 40 years so I guess she’s worth the $22 plus $6.95 shipping. :-)
View Davevand's profile
Davevand
244 posts in 1846 days
#9 posted 12-28-2020 10:05 PM
I scroll saw my own, not hard to make
Andybb
#10 posted 12-28-2020 10:22 PM
- Davevand
Not for you! :-) My scroll work is as bad as my handwriting.
View Lazyman's profile
Lazyman
6640 posts in 2397 days
#11 posted 12-28-2020 11:13 PM
If the cross is all you are doing, you could easily do that with a couple of straight edges and stops.
HokieKen
#12 posted 12-28-2020 11:56 PM
Andy will need a template that does both the cavity and the inlay though. Not as simple as straight edges and stop block unfortunately. I have made templates with a scroll saw as well. Lots of sanding to get a usable template though… Sounds like Andy’s about on par with me when it comes to that :-)
Lazyman
#13 posted 12-29-2020 01:51 AM
Since the cross is made from 2 rectangles, I seems like it would be fairly easy to make the inlay pieces, perhaps even on the table saw. You would just have to round the corners on the ends of the inlay pieces to fit the pocket.
BTW Kenny, I always wondered how you got the inside corners on your makers mark inlay sharp (not rounded) using a router?
Andybb
#14 posted 12-29-2020 01:58 AM
- Lazyman
Thanks for the belief in my skills but this is definitely a job for a template. I’ve used my Whiteside/Rockler inlay kit for countless butterflies. Wouldn’t attempt it any other way. Double-sided tape, cut the hole, cut the insert, done. Plus, a 3” multilayer cross would look classy. Well worth the $22. :-)
- Lazyman
I know from experience that is not as easy as it sounds and I’d spend hours setting it up. Then I’d have to set it up again after testing it on my practice piece. Way too much work and opportunity to screw it up, which i have been known to do, vs $22! Tape, cut, cut done!! 15 mins tops. I’m lazy, Lazy!
Hire the lazy man. He may not do as much work but that’s because he will find a better way for $22 :-)
View Rich's profile
Rich
#15 posted 12-29-2020 02:01 AM
An inlay template with an inlay bushing can cut the inlay and the pocket using the same template such that they fit perfectly. Corners in the pocket are squared with a chisel. The other option is to round the corners of the inlay. It all depends on what look you’re going for.
showing 1 through 15 of 69 replies
