Forum topic by Bobby870 | posted 12-28-2020 01:48 PM | 624 views | 0 times favorited | 11 replies | ![]() |
I am working on installing quarter round and can’t figure out why my inside corners are looking like this. The joint is tight but the coped 45 piece never meets with the back end of the butt joint. Should the very top of the cope be at the back end of the other trim piece or will it always be like this and not go all the way to the back of the other trim piece? |
11 replies so far
#1 posted 12-28-2020 03:12 PM |
Did you intend to post a photo? It’s hard to answer without it. |
#2 posted 12-28-2020 09:46 PM |
Hi Bobby I think you need at least 5 posts before you can add a pic, so you probably need to describe it more or make more posts. Inside joint should look like this. -- Be yourself; everyone else is already taken. |
#3 posted 12-29-2020 12:16 AM |
I think I figured it out after many trials and changing the angle I was coping the trim at. Attached is a picture of what I kept getting where the joint was not going all the way back. I realized that when I got towards the bottom of the trim piece when I was coping it, I wasn’t back cutting it enough at the bottom, my cut was getting almost vertocle only. When I changed that angle at the bottom of the back cut, I now have the coped joint all the way to the back of the other joint. |
#4 posted 12-29-2020 12:22 AM |
Here is the correct joint after I changed the angle of backcut. |
#5 posted 12-29-2020 12:29 AM |
Is it me… or does anybody else find it is easier to cope with a slightly dulled blade? |
#6 posted 12-29-2020 02:16 PM |
For small quarter round consider using a Dremel with the sanding drum. -- Woodworking, the transformation of nature to culture. |
#7 posted 12-29-2020 05:09 PM |
Don’t obsess. Once you put a coat of paint on it no one will notice. After all it is toe molding, not exactly at eye level. Once you’ve coped the piece, back cut with a pocket knife to perfect the fit. -- The hump with the stump and the pump! |
#8 posted 12-29-2020 06:12 PM |
Thing about Cope cuts is, if you do them all the time, it’s a muscle memory thing. If you don’t do them all the time, but want them to be flawless without a lot of fooling around, you buy an Easy Coper. http://www.easycoper.com/crown_molding_coping_jig.htm -- Think safe, be safe |
#9 posted 01-18-2021 02:59 PM |
I cope w/Bosch barrell grip jigsaw an their scroll blades. Not for stain grade but fine for paint. An/or I’ll cut inside corners on a 44- degree, outside on a 46 -- I actually have two thumbs. Both prehensile and opposing. |
#10 posted 01-18-2021 04:47 PM |
I use a dowel wrapped with sandpaper. |
#11 posted 01-19-2021 07:26 AM |
Use some Timber mate wood putty in there. leave it for 20 minutes, wipe of the excess with a wet cloth, paint over it and no worries! |
Forum | Topics |
Woodworking Skill Share
13199 |
Woodturning
2814 |
Woodcarving
569 |
Scrollsawing
416 |
Joinery
1893 |
Finishing
6345 |
7906 |
32761 |
CNC Woodworking
330 |
Hand Tools
6453 |
Jigs & Fixtures
1804 |
Wood & Lumber
7276 |
1633 |
Focus on the Workspace
2632 |
1272 |
Woodworking Trade & Swap
5417 |
LumberJocks.com Site Feedback
2396 |
Coffee Lounge
9658 |
