Gilding Misfire - Any way to save this project?
Forum topic by TTH posted 12-21-2020 03:41 PM 726 views 0 times favorited 9 replies Add to Favorites Watch
View TTH's profile
TTH
32 posts in 639 days
12-21-2020 03:41 PM
Ugh, never the post you want to make four days before Christmas but here goes.
I tried using gold leaf for the first time and have apparently screwed the pooch.
I cut my stencil into contact paper and placed it on the piece. I think the lacquer must have not fully cured because now the whole surface of the piece is tacky where the contact paper was sitting on it, and it’s kept me from brushing off the excess leaf, which is just stuck now.
Short of sanding everything off the surface of the wood and starting over again, is there anything I can do to salvage this?
-- Travis, DFW
9 replies so far
View GR8HUNTER's profile
GR8HUNTER
9313 posts in 2047 days
#1 posted 12-21-2020 04:04 PM
i would try acetone small drop :<)))
-- Tony---- Reinholds,Pa.------ REMEMBER TO ALWAYS HAVE FUN :<))
View Rich's profile (online now)
Rich
7747 posts in 1924 days
#2 posted 12-21-2020 04:09 PM
Acetone or lacquer thinner and Qtips.
View drsurfrat's profile
drsurfrat
1226 posts in 521 days
#3 posted 12-21-2020 04:11 PM
You might find a selective solvent that will deal with the adhesive, but leave the lacquer and gold leaf alone.
alcohol (supposedly will not damage lacquer)
mineral spirits – might be ok
acetone – probably not, but if desperate, do it quickly
naphtha (can melt lacquer, but not immediately)
white gas ?
hot water ?
Maybe first see if it will dissolve the adhesive on the contact paper alone, then carefully see if it will leave the lacquer and gold leaf alone. It might even be worth making a test piece at least with lacquer to try first.
-- Mike (near Boston) ... Laziness is the mother of invention, necessity is the mother of exhaustion - me
drsurfrat
#4 posted 12-21-2020 04:15 PM
Or maybe just local scraping and then outline/pinstripe each letter… I’m cringing as I write this.
View BlueRidgeDog's profile
BlueRidgeDog
905 posts in 1113 days
#5 posted 12-21-2020 04:31 PM
Odd Lacquer is really really fast. Perhaps the residue is from the transfer paper. Try alcohol on a cloth…it should not lift the lacquer.
View Brawler's profile
Brawler
216 posts in 1165 days
#6 posted 12-21-2020 04:33 PM
I don’t know what goo-gone would do to the finish, but it would get rid of the adhesive. You could try a little on a scrap piece to see if it hurts your finish.
-- Daniel, Pontiac, MI
View TTH's profile
TTH
#7 posted 12-21-2020 04:44 PM
- BlueRidgeDog
Do you mean denatured alcohol or do you think regular rubbing alcohol would do?
-- Travis, DFW
BlueRidgeDog
#8 posted 12-21-2020 05:09 PM
I would try any alcohol I could lay my hand on just to see it was the paper backing that was the issue.
View Madmark2's profile (online now)
Madmark2
3254 posts in 1922 days
#9 posted 12-21-2020 07:02 PM
Comb with a razor blade corner to remove the leaf. Any solvent will make it sink in and bond.
-- The hump with the stump and the pump!
