newbie needs help
Forum topic by lengal posted 12-18-2020 10:09 PM 888 views 0 times favorited 36 replies Add to Favorites Watch
View lengal's profile
lengal
24 posts in 278 days
12-18-2020 10:09 PM
I will start by saying that I am not a woodworker or carpenter. I am a retired welder.
I am building a twin size platform base with drawers copying the platform base from a Jon Peters video. The video was about 30 minutes long and well done. After drawing up my plans, I got right to the build. After each days work, I would go look at his video again to keep me on track and found that he also has a few shorter breakdown video’s of each section of his build. This is where I need the help. On Jon’s short drawers video, he says he will apply 2 coats of polyurethane to the inside where the drawers will go. That was not mentioned in the long video. My platform box is 37 1/2” deep by 9 1/2 high and put together with screws and glue. I don’t see myself being able to apply the poly, sand it and apply a second coat.
So my question is, do I really need to protect the wood with anything or can I leave it bare? It is going in a bedroom. The drawer fronts and the poplar face will be painted and I can protect the outside of the platform so, I’m really only concerned about the inside where the drawers go. Not sure what to do at this point.
Any information will be greatly appreciated.
PS. Its cold here in Philly and my garage is not heated. Drying concerns also!!!
Don’t know why the picture came up sideways
36 replies so far
View Sycamoray's profile
Sycamoray
95 posts in 454 days
#1 posted 12-18-2020 10:20 PM
I never finish the inside of a project with polyurethane. In an enclosed space like behind a drawer, or in a drawer for that matter, the volatiles take seemingly forever to gas off, and the finish effectively contaminates whatever is in the space. The rare times I need to finish the inside of something, I use shellac.
Go ahead and paint the exteriors, etc. and move on with your life.
View SMP's profile
SMP
4724 posts in 1119 days
#2 posted 12-18-2020 10:52 PM
I have never really finished the inside of anything except cabinets where you see the inside, and drawer boxes. But lately I have just been buying the pre-finished baltic birch for drawer sides. If I am not going to see it again, it doesn’t usually get finished.
View HowardAppel's profile
HowardAppel
113 posts in 4248 days
#3 posted 12-19-2020 01:26 AM
I haven’t seen the specific videos to which you refer, but I know that Jon sometimes uses prefinished plywood and sometimes uses a sprayer. Having said that, I doubt that not finishing the inside will make a huge difference.
lengal
#4 posted 12-19-2020 01:37 AM
Thanks for the replies. I’m happy to hear that I can go without finishing the inside. I’ll get back on it tomorrow
I haven t seen the specific videos to which you refer, but I know that Jon sometimes uses prefinished plywood and sometimes uses a sprayer. Having said that, I doubt that not finishing the inside will make a huge difference.
- HowardAppel
https://www.youtube.com/watch?v=vsy7leNPvZI
lengal
#5 posted 12-19-2020 01:38 AM
- https://www.youtube.com/watch?v=vsy7leNPvZI
View DrTebi's profile
DrTebi
402 posts in 4480 days
#6 posted 12-19-2020 06:35 AM
- Sycamoray
I completely agree with what Sycamoray said above.
One thing to note however is, if I looked at the right video, that the drawers are not having any runners. If that is so, I would suggest to put a good amount of paste wax on the bottom of the interior (where the drawers ride on), and on the drawer bottom edges as well. This will make a hell of a difference in how nice they will glide…
View Madmark2's profile
Madmark2
3059 posts in 1802 days
#7 posted 12-19-2020 06:42 AM
I use Johnson’s paste wax as a shop finish on most everything. It can be easily stripped and replaced with any finish if required. Wax doesn’t need sanding between coats and two slatherings will give a decent finish that dries quick, doesn’t outgas (much) and looks and feels better than plain wood.
-- The hump with the stump and the pump!
View ibewjon's profile
ibewjon
2598 posts in 4007 days
#8 posted 12-19-2020 11:30 AM
I use the drawer glide tape from Woodcraft in place of wax. Peel and stick to the base, and the heavy drawers glide in and out.
View BlueRidgeDog's profile
BlueRidgeDog
884 posts in 993 days
#9 posted 12-19-2020 12:38 PM
For dimensionaly stable case work made from sheetgoods, finishing the inside is optional (IMHO). For a piece like yours, If I did not put finish on before the glue up, I would certainly not be finishing it after and give it a second thought to leave it as is. If I want to finish the inside of a piece, then shellac or lacquer is the way to go or simply a coat of wipe on sealer such as seal-a-cell.
Your project is looking good. Best of luck on the outcome.
View JIMMIEM's profile
JIMMIEM
232 posts in 2055 days
#10 posted 12-19-2020 02:28 PM
Besides not needing to apply a finish to the inside, as others have already said, applying poly in a garage in the winter in Philly will be a real problem. I was applying poly in my unfinished basement in the winter and had to use one of those oil filled radiators to get the air temp high enough so that the poly would flow correctly.
Question: What kind of glue are you using? Kind of cold in the garage.
lengal
#11 posted 12-19-2020 03:24 PM
I have a kerosene forced air heater that I use to warm up the garage. I let it run for a while to get up to about 65 degrees then turn it off and on to keep cozy. The garage is very drafty so fresh air comes in constantly from above the rafters.. I am using titebond ll for glue with screws
lengal
#12 posted 12-19-2020 03:28 PM
Any suggestions on what I should put on the top where the mattress will sit. I was gonna put polyurethane on it but maybe I should put something else on top. Or, do even need to seal it on top?
lengal
#13 posted 12-19-2020 03:32 PM
- Sycamoray
- DrTebi
- Sycamoray
- DrTebi
I will use the paste wax on the bottom. thanks
lengal
#14 posted 12-19-2020 03:36 PM
Just to let you guys know, I am not good with computers. I’m trying to reply to some of the posts with the quote button and I don’t know if I am doing it right. So please bare with me
JIMMIEM
#15 posted 12-19-2020 04:35 PM
Just to let you guys know, I am not good with computers. I m trying to reply to some of the posts with the quote button and I don t know if I am doing it right. So please bare with me
- lengal
Just click the quote button and start typing your reply on the line below the blockquote.
I use polyurethane top, bottom, inside, outside. Once the offgassing smell goes away everything will be fine. Sometimes the offgassing can take a while to dissipate.
showing 1 through 15 of 36 replies
