Forum topic by Jimothy | posted 12-16-2020 07:07 AM | 668 views | 0 times favorited | 9 replies | ![]() |
I was wondering, are dowels affective in plywood? I am mildly confused due to the fact that the grain direction alternates rvery layer. Gluing plywood together is essentially gluing a surface which is partially side grain and also partially end grain. I am building a dresser and plan to use dowels for assembly. Is there a benefit to using dowels in this case? Is it redundant considering I’m creating a hole, and that dowel isn’t even adhering to side grain only. Just not sure if it’s worth it or will actually make a different or possibly cancel itself out. |
9 replies so far
#1 posted 12-16-2020 01:02 PM |
Yes you can use dowels in plywood successfully, but. |
#2 posted 12-16-2020 07:18 PM |
I will second what jkm312 said. Let me emphasize what he said about the right size hole; particularly when using plywood. Remember that your dowels are like pistons. Particularly when glue is applied, clamping the joint closed can put a tremendous amount of pressure on the sides of the hole and can easily de-laminate the plies. Make sure your dowels have grooves to allow excess glue to escape and make your holes slightly deeper than the dowel by perhaps 1/8”. IMO, splines in plywood are easier and less apt to cause problems but there is nothing wrong with dowels. |
#3 posted 12-17-2020 05:11 AM |
Biscuits work well with plywood, and are very easy to do. -- I admit to being an adrenaline junky; fortunately, I'm very easily frightened |
#4 posted 12-17-2020 05:52 AM |
I’m currently working on a kitchen cart (my 2nd of this particular design). It’s basically a plywood lower cabinet on wheels. I use dowels to attach 3/4×3/4” hardwood trim to cover the plywood edges. For various reasons throughout the build it’s nice to dry fit the trim, like measuring and test fitting adjacent parts. I use high quality 3/4” ply, a cheap Milescraft doweling jig, dowel centers to line things up, and fluted dowels. I’ve used 1/4” and 3/8” diameter dowels without any issues. Also, you mention you’re building a dresser. What parts are you using the dowels for? If you’re talking about attaching the horizontal pieces (bottom/top/shelves) to the sides, I think a dadoe and glue would be stronger. But if you’re talking about things like stretchers or face frame then go for the dowels or biscuits. -- ~Walker |
#5 posted 12-30-2020 11:12 PM |
After watching some strength testing videos, apparently biscuits are not particularly good at adding much strength |
#6 posted 12-30-2020 11:48 PM |
This may be a very good read for this question. The author asks how strong is a dowel joint, but tests all of the usual suspects. https://www.canadianwoodworking.com/get-more/how-strong-dowel-joint It used a M&T, which many will say is the same strength as a Domino loose tenon, it didn’t fare as well as some other similar studies which often has the Domino first. I do know a Domino is as easy as a biscuit, but a darn site tougher. It’ll be interesting to see what other tests are brought up. But I can say from experience a dowel is a LOT tougher than a biscuit. -- Think safe, be safe |
#7 posted 12-31-2020 12:03 AM |
Show some pictures of what you intend to build, so we can give you the best possible answers for your situation. I can’t say I’ve ever used dowels in plywood. Usually my plywood panels go inside a hardwood frame. Corner joints? What are we talking about here? -- Willie, Washington "If You Choose Not To Decide, You Still Have Made a Choice" - Rush |
#8 posted 12-31-2020 12:20 AM |
okay basically it’s all butt joints which I am planning to reinforce with dowels. But my question isn’t really regarding what joint is the best in this scenario, the question is more does the alterating ply’s aka alternating grain directions every other layer kind of defeat the purpose of using dowels or some other reinforcement which is intended to add a face grain to face grain gluing surface(s) whereas otherwise it would be end to end. A plywood edge is partially end grain and partially face grain because of the plys alternating. so gluing two plywood edges together would be basically halfway between the standard face to face grain glue joint and an end grain to end grain glue joint. If we added dowels to the equation, the dowel inside the dowel hole will also be bonding with both a combination of face and end grain, exactly like if we hadnt added dowels at all.
#9 posted 12-31-2020 01:19 AM |
I liked these videos -- Just a Duffer |
Forum | Topics |
Woodworking Skill Share
13205 |
Woodturning
2815 |
Woodcarving
569 |
Scrollsawing
416 |
Joinery
1900 |
Finishing
6352 |
7914 |
32786 |
CNC Woodworking
330 |
Hand Tools
6456 |
Jigs & Fixtures
1809 |
Wood & Lumber
7284 |
1634 |
Focus on the Workspace
2637 |
1272 |
Woodworking Trade & Swap
5421 |
LumberJocks.com Site Feedback
2396 |
Coffee Lounge
9664 |
