Forum topic by Steinbierz | posted 12-11-2020 06:30 PM | 394 views | 0 times favorited | 14 replies | ![]() |
I am looking to install an air filtration system in my 1500 sq. ft. shop and have been investigating options. I have a Felder RL 160 Dust Extraction system as my main dust/chip collector. It seems from the many, many shop videos that I have watched online that Jet pretty much seems to rule the roost! I see others mentioned like HF, Grizzly, etc. but not to the extent that Jet is. After reading an article on Highland Woodworking discussing the virtues of a Rabbit Air system, I thought I might go that route. However, the few reviews I’ve seen from other woodworkers on this system complained about how expensive they were, the low CFM, and filter expense so I am probably going to scratch this unit from consideration. Plus, I would most likely need two of these units for my shop. So, is Jet still the main player out there or are there other units that I am not aware of? Thanks. -- Larry ~ Alvin, TX (Home of Nolan Ryan) |
14 replies so far
#1 posted 12-11-2020 06:42 PM |
Many of us have made our own. Either using box fans or in my case a used residential air handler squirrel cage blower for a heating system for a 3000 foot home. The used blowers are often available for little or no cost from heating contractors. Mine is built into a floor cabinet with wheels so I can move it around where it is most needed and it also serves as a work top for my sharpening tools. In the winter it doubles to circulate the heat from my wood stove. -- Les B, Oregon |
#2 posted 12-11-2020 06:49 PM |
The thought of moving a filter around to where you really need it at the time makes a lot of sense! -- Larry ~ Alvin, TX (Home of Nolan Ryan) |
#3 posted 12-12-2020 12:00 PM |
I have a ceiling mounted PowerTec: I upgraded the primary filter to a Merv 8: The PowerTec appears to be the same as a: Jet, Rikon, or Wen. Probably all were manufactured at the same factory. It works very good in my basement shop. I need to replace the primary filter every three months. I’m also considering a second one for the other side of the basement, (probably a Wen or Jet) to assist with air flow, as my basement stairwell comes down into the center of the space. Edit: I just ordered a second PowerTec AF1045 directly from PowerTec. $299 + free shipping. -- "In the end, it's all Hack..." |
#4 posted 12-12-2020 12:10 PM |
I have the Jet and very happy with it. Howrver , with a big shop, I would build one with a good sized squirrel cage fan. I would build as a roll around cart. |
#5 posted 12-12-2020 01:49 PM |
I have the Jet AFS-1000. And it works great in my 600sf shop. But I see that jet does make a larger unit. With your large shop maybe it will be the one for you. So I have read that the air filter should be in one end of the shop. But everyone I know has mounted there air filter in a central area hanging from the ceiling. -- John |
#6 posted 12-12-2020 03:22 PM |
If anyone in the Dallas area wants to build there own, I have a blower/squirrel cage fan from a furnace that I replaced that they can have for free. Funny thing is I was going to throw it away last week but I got side-tracked and left it sitting on the shelf when I went to the landfill. It’s semi large and heavy so shipping is not an option. Send me a PM if interested. -- NorthWoodsMan |
#7 posted 12-12-2020 03:26 PM |
Jet does seem to be the main player in the market, but WEN seems to have a very similar model for cheaper. I have the Jet 1000 (mounted on the side wall), but I’ve seen lots of references to folks being very happy with the WEN. I don’t know if the specs are identical, but you could check. With your large space, you might need two. |
#8 posted 12-12-2020 03:36 PM |
You are probably correct about them all being made in the same factory! -- Larry ~ Alvin, TX (Home of Nolan Ryan) |
#9 posted 12-12-2020 03:53 PM |
I was wondering whether I would need two as well. Whichever unit I decide on I may start with one first located in the area where the most dust production will occur and add later if I need to. -- Larry ~ Alvin, TX (Home of Nolan Ryan) |
#10 posted 12-12-2020 03:54 PM |
Interesting about the positioning comment…I had assumed that mine would be located somewhat in the middle of my shop as well. -- Larry ~ Alvin, TX (Home of Nolan Ryan) |
#11 posted 12-12-2020 03:56 PM |
This is probably a very good idea. The only thing that keeps me from going this route is I have a lot more available overhead space than I do floor space so will most likely go with something hanging from the ceiling. -- Larry ~ Alvin, TX (Home of Nolan Ryan) |
#12 posted 12-12-2020 04:10 PM |
I went with the lower $$$$$ Griz a while back when they were on a sale too good to believe. I bought 2 though, as they are lower on the scale, with both running I can see quite a difference though. I don’t have mine hanging static. I move them around and have them sitting on benches, and counter spaces. That way I can home in on where I am working. I feel like having them around my head, or just below is what I want to protect, with them off that is also about the height I can see the dust floating around. I have 12’ ceilings, and the dust never gets close to that height, hardly anything above 6 to 8’ in my shop. I’m 6’ 2” so I want that to go away. Mine will run on a side, the top or the bottom, so I can change orientation, to get what I need from them. I have a few friends with hanging units with huge specs, and looking at them you can see what looks like a cone, where it’s pulling dust through the air. You can see the dust by looking out a window, and move around to see where it is heavier, or nothing at all. I’d say I’ve seen an area of maybe 15’ around, past that not so much. That was what made me decide on getting 2, surround myself with air flow. Seems like it works. -- Think safe, be safe |
#13 posted 12-12-2020 05:20 PM |
One problem with putting them down low is that the exhaust may be more likely to stir up anything that is laying on the ground or even on machines. I’ve always thought it makes sense to hang from the ceiling with 2 units at opposite ends of the space such that the exhaust sort of create a current around the shop. The current may help keep fine dust in suspension longer so that it is more likely to be filtered instead of settling out out around the shop. Also, you may need to consider the cubic footage in addition to square footage when figuring out how much filtration you need. -- Nathan, TX -- Hire the lazy man. He may not do as much work but that's because he will find a better way. |
#14 posted 12-12-2020 06:10 PM |
I have several friends that are professional woodworkers. And there air filters are all mounted sort of centered. And much higher than mine. I am in a 3 car garage with 9’ ceilings. But the pro shops have much higher ceilings, warehouse type structure maybe 20’ tall. And air filter is mounted 10 to 12 feet up, hanging from chains. The mention of home made filters, Then I picked up the Jet. The home made one was less money, but cost me the build time and alot of filters. -- John |
Forum | Topics |
Woodworking Skill Share
13203 |
Woodturning
2815 |
Woodcarving
569 |
Scrollsawing
416 |
Joinery
1900 |
Finishing
6350 |
7913 |
32784 |
CNC Woodworking
330 |
Hand Tools
6456 |
Jigs & Fixtures
1808 |
Wood & Lumber
7284 |
1634 |
Focus on the Workspace
2637 |
1272 |
Woodworking Trade & Swap
5421 |
LumberJocks.com Site Feedback
2396 |
Coffee Lounge
9664 |
